jbl 6 disc with sub and amp
Discussion in 'Audio & Video' started by jasonh, Jun 28, 2008.
  1. Jun 28, 2008 at 8:29 AM
    jasonh
    jasonh [OP] tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    i have the regular 6 disc cd changer in my double cab pre-runner. does anyone know if i will have to do any wireing or splicing to make the sub and amp work in my truck. if so how difficult will it be?
  2. Jun 30, 2008 at 12:51 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    So you bought a Sotck HU to replace the one currently in your truck and also want to install a JBL stock sub and amp?
    If i am reading this right you would be much better off installing an aftermarket Amp box and sub and would get much better performance.
    If you want to do this via the stock HU... yes it is possible but you need to get a "line out" i think is what they are called... They serve their purpose but they are not ideal, they convert the speaker signal to an RCA so you can hook up an AMP then power your subs.
    i hope this helps... please fill us in if i didn't answer your questions.
  3. Jun 30, 2008 at 1:12 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    you need an amp that has a line input on it or a line level converter.
  4. Jul 5, 2008 at 10:16 AM
    Playz
    Playz Pepsi
    Whittier
    08 TRD Sport 4x4
    Flowmaster muffler, KandN intake
    I wouldn't install any factory audio. Aftermarket is better and sounds alot better.
  5. Jul 5, 2008 at 10:41 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Aftermarket is the way to go.
  6. Jul 7, 2008 at 12:47 PM
    shonuff505
    shonuff505 Member
    Albuquerque
    05 4x4 SR5 Blue Beast
    Billet Grill
    You can get a custom speaker enclosure from ebay for both 10" and 12" subs for around $100. you would be better off saying yourself some time and money by just going aftermarket. you wont be happy with the JBL.
    Semper Fi
