JBL/Dynamat Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011Streaker, Jan 17, 2017.
  1. Jan 17, 2017 at 5:24 PM
    2011Streaker
    2011Streaker [OP] Well-Known Member
    Maine
    2012 DCSB TRD Sport
    Greetings,
    I purchased a used Sport DCSB w/ JBL recently. When the bass really thumbs, the whole plastic area behind the rear seat vibrates and sounds bad. I am not an audiphpile so I know nothing about this. I tried searching but either I am searching the wrong thing or there's no threads. Anyhow, would sound insulation stop this vibration?
    If so, Once I removed the plastic behind the rear seat, would I put the stuff on the inside back of the plastic or on the metal of the cab?
    Thanks
  2. Jan 17, 2017 at 5:46 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  3. Jan 17, 2017 at 6:02 PM
    2011Streaker
    Maine
    2012 DCSB TRD Sport
    is this a stupid question? i really want to stop that noise but i dont know what im doing.
  4. Jan 17, 2017 at 6:14 PM
    tomrtrd
    tomrtrd Member
    tom
    06 Tacoma 4X4
    ALARM @ REMOTE START, 2" LEVELING LIFT
    you might have a factory sub back there
  5. Jan 18, 2017 at 4:56 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    I ditched mine, and dynamat then carpeted the rear wall. I found there is WAY more room back there without those bins. Anyway, yes a good place to start would be to dynamat the back wall then reinstall the plastic trim.
  6. Jan 18, 2017 at 6:57 AM
    2011Streaker
    Maine
    2012 DCSB TRD Sport
    Yeah theres a sub back there, but it sounds cheap when the whole back wall vibrates. I'll try the dynamat on the back wall and see if it helps.
    Thanks
  7. Feb 2, 2017 at 7:36 PM
    toyotacoblur
    toyotacoblur Active Member
    Orange County, CA
    09 DC TRD Sport Long Bed
    You should check and see if the clips are missing or broke. There are about 4 screws that mount the sub and amp to the wall and floor. One of the screws is the one that holds the plastic in place as well. Then there are a few clips part number 90467-10161. If these are missing or broken then it will vibrate. I have a 2009 and i have had no vibration unless i put something in the bin next to the sub that is loose. I just pulled mine apart tonight so this is fresh info :)
    Found a video that shows how to remove https://www.youtube.com/watch?v=yEcowYsoW-c skip to 1:42 for rear removal process.
  8. Feb 5, 2017 at 12:36 AM
    2011Streaker
    Maine
    2012 DCSB TRD Sport
    thats great, thanks. i think one of the clips was broken. i did take the shelf thing out on that side and just left it, no more vibe issues. :p
  9. Feb 5, 2017 at 1:46 AM
    toyotacoblur
    Orange County, CA
    Glad it helped! I picked up a bag of 20 of those clips on Amazon for $8, part number 90467-10161. I'm gonna dynamat that area while i deal with my roof leak, but wih all those clips in it wont rattle :)
