JBL HU wiring?
Discussion in 'Audio & Video' started by Zonktified, Apr 2, 2013.
  1. Apr 2, 2013 at 12:11 PM
    Zonktified
    Zonktified [OP] Well-Known Member
    Rob
    Wisconsin
    Tacoma TRD Sport
    Planning on adding a sub to my system, 2012 JBL HU, and was wondering if anyone knows if it has pre-amp (RCA) outputs for a sub amp?
    This would help me plan on what I need to purchase short of pulling out the system just to check....thought I'd ask the gurus here on TW.
    Edit for clarity: this is the navi HU incase it makes a difference...anyone?
  2. Apr 2, 2013 at 2:25 PM
    Aw9d
    Aw9d That one guy
    Az
    There are no RCA pre-outs on the stock HU's.. You need to buy adapters for that. And the harness for JBL is over 100$, then you gotta get adapters.
  3. Apr 3, 2013 at 3:08 AM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    Most just use line output converters which aren't very expensive at all .
  4. Apr 3, 2013 at 7:07 AM
    Zonktified
    Rob
    Wisconsin
    Tacoma TRD Sport
    Thanks guys...one more question...Is there a place I look to identify the wire colors for the rear speakers so that I can tie into them...or would anyone know this info by chance?
  5. Apr 3, 2013 at 9:09 AM
    Zonktified
    Rob
    Wisconsin
    Tacoma TRD Sport
    I was able to find this info from http://www.modifiedlife.com/2012-toyota-tacoma-car-audio-wire-diagram/ if anyone else is interested...
    2012 Toyota Tacoma Car Audio Wire Diagram
    Car Radio Battery Constant 12V+ Wire: Light Blue
    Car Radio Accessory Switched 12V+ Wire: Gray
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: Green
    Car Radio Dimmer Wire: N/A
    Car Radio Antenna Trigger Wire: N/A
    Car Radio Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Tweeter Size: 1 1/2″ Tweeters
    Car Audio Front Tweeter Depth: 1 1/2″
    Car Audio Front Tweeter Location: N/A
    Left Front Speaker Positive Wire (+): Pink
    Left Front Speaker Negative Wire (-): Violet
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Blue
    Car Audio Front Speakers Size: 6″ x 9″ Speakers
    Car Audio Front Speakers Depth: 4″
    Car Audio Front Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): N/A
    Left Rear Speaker Negative Wire (-): N/A
    Right Rear Speaker Positive Wire (+): N/A
    Right Rear Speaker Negative Wire (-): N/A
    Car Audio Rear Speakers Size: 6 1/2″ Speakers
    Car Audio Rear Speakers Depth: 3 3/5″
    Car Audio Rear Speakers Location: N/A
    Car Subwoofer Speaker Positive Wire (+): N/A
    Car Subwoofer Speaker Negative Wire (-): N/A
    Car Subwoofer Speaker Size: N/A
    Car Subwoofer Speaker Depth: N/A
    Car Subwoofer Speaker Location: N/A
    The 2012 Toyota Tacoma radio wire color information above is updated as it is submitted by the Modified Life community
  6. Apr 3, 2013 at 9:29 AM
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    columbia, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    here are the rear wire colors and location..
    only with jbl!
    the wires are at the amp which is located on the right rear cabin wall..
    -left rear speaker wires black(+) and yellow(-) wires are in the blue 10 pin plug pins 3 & 9 at the amp on the back wall..
    -right rear speaker wires red(+) and white(-) wires are in the blue 10 pin plug pins 10 & 4 at the amp on the back wall..
    the factory sub wires are paralleled with the rear speakers..
    hope this helps
