JBL Premium Upgrade. Replacing speakers and subwoofer.
Discussion in 'Audio & Video' started by bonifacio, Apr 8, 2021.
  1. Sep 16, 2021 at 4:22 AM
    #81
    captainvfr
    captainvfr Member
    2020 Limited Cement
    Advice please. I have a 2020 Limited w/JBL head and stock sub, upgraded 2ohm dash and door speakers, however, although the sound is better it still needs more power. I am struggling with finding a compatible amp in lieu of spending $2800 for the OEM Audio amp/DSP solution.
    Other option I would consider if it will make a difference is upgrading the sub.
    Thank you for the help.
    KobyTaco19 and teledude like this.
  2. Sep 16, 2021 at 6:45 AM
    #82
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I am planning on getting this amp.
    JBL DSP4086 8-channel car amplifier with digital signal processing — 40 watts RMS x 8 at Crutchfield
    D. Lengua likes this.
  3. Sep 23, 2021 at 8:37 AM
    #83
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
  4. Sep 23, 2021 at 5:56 PM
    #84
    TacoManOne
    Paul
    Liberty Lake, WA
    Will do. Hopefully before winter since my truck doesnt fit in the garage
  5. Sep 24, 2021 at 3:36 AM
    #85
    D. Lengua
    '21 Limited LB
    lol, same here.
  6. Sep 25, 2021 at 4:48 PM
    #86
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Op did you give up on your speakers?
  7. Nov 1, 2021 at 12:29 PM
    #87
    Elluis1305
    Elluis1305 Member
    2019 Tacoma TRD Pro
    Hi, I want to do the same, what speakers did you go to? The problem I have is that when I go past 47 in the volume meter I loose all the high end of the frequecies and get pure mids and bass, the volume is ok, but the clarity is lost, I was thinking of going with the component speaker set.
    Thanks
  8. Nov 1, 2021 at 12:54 PM
    #88
    Elluis1305
    Elluis1305 Member
    2019 Tacoma TRD Pro
    Hi, can I ask why didn't you go with a component speaker set to take advantage of the built-in crossover in the factory set up, I am not genius, but I think the 3-way 6x9's you put on are not going to be the best application since the system will only send low end frequencies to those speakers.
    I want to do the same, keep stock amp and subwoofer but change all door and dash speakers for a component set and just regular 2-way 6.5 for the rear doors.
    Thanks for all the info!
  9. Nov 24, 2021 at 5:03 AM
    #89
    TacoManOne
    Paul
    Liberty Lake, WA
    Ordered the JBL DSP amp. Comes today. Install soon. Weather depending.
    D. Lengua[QUOTED] likes this.
  10. Dec 4, 2021 at 5:44 AM
    #90
    D. Lengua
    '21 Limited LB
    it's only getting colder out there....:)
    TacoManOne[QUOTED] likes this.
  11. Dec 4, 2021 at 5:48 AM
    #91
    TacoManOne
    Paul
    Liberty Lake, WA
    Hopefully this weekend.
  12. Dec 20, 2021 at 4:22 PM
    #92
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    Just seeing if there’s any updates to the amp install. @TacoManOne
  13. Dec 20, 2021 at 4:34 PM
    #93
    TacoManOne
    Paul
    Liberty Lake, WA
    Getting closer. Had a MAJOR project to cleanup and organize the garage. The Taco might fit in now.
  14. Dec 21, 2021 at 12:21 PM
    #94
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Thanks for these pictures! I had previously cut off the connectors and wired directly to the new sub. But going back to check this I got one of them backwards
    Connection 1: red = positive, yellow = negative
    Connection 2: black = positive, green = negative
    TacoManOne likes this.
  15. Dec 23, 2021 at 7:34 AM
    #95
    AZJuice
    AZJuice Well-Known Member
    Juice
    Arizona
    16 Taco DCLB Sport 4x4
    Happy Holidays! Any updates or did I miss something?
  16. Jan 20, 2022 at 9:25 PM
    #96
    TacoManOne
    Paul
    Liberty Lake, WA
    Ok so the JBL DSP amp is installed!!!!!! When my fingers thaw, I will do a writeup. LOL. Somewhat unconventional amp location but it works great. Took lots of photos.
    Froze my butt off in sub-freezing weather but definitely worth it. WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAYYYYYY better system. LOUD, much better bass, no loss or power cut down when playing loud for more than 5-10 minutes. Or at least that what seemed with the stock amp. Much better system and I have not even tuned it yet!
    The instructions that came with it for the DSP software SUCK. on a really good day. I will reorder this from install to tuning once I am done.
    DSP Settings
    Used a Leica Disto laser measuring device to get the distances for delay.
    Location / Speaker Model / Distance including depth of speaker (read/watch the video to see why)/distance from grill to cone/spider interface.
    LFT / JBL GX 302 / 30.50 in / 1.5 in
    RFT / JBL GX 302 / 49.50 in / 1.5 in
    LFW / JBL GX 963 / 43.00 in / 2.0 in
    RFW / JBL GX 963 / 55.00 in / 2.0 in
    LRD / JBL Club 6522 / 36.00 in / 2.0 in
    RRD /JBL Club 6522 / 56.00 in / 2.0 in
    SUB / Polk MM842 DVC / 56.00 in / 3.0 in
    For reference
    LFT - left front tweeter, but my speaker is 2 way, more on this later
    RFW - right front woofer, but speaker is 3 way, same
    LRD - left rear door, 2 way speaker
    Etc.
    Woofer - dual voice coil speaker
    So here are some links to help on the software side. I spend a few hours messing around with it and will spell out what to do in what order to save you some time.
    Do this in the order below since it lays the foundation for the video. I run the sound board at our church and have done mixing for years with analog and now digital boards so I started with a slight advantage.
    1. What Should I Set My High Pass Filter To? (soundcertified.com)
    2. What Should I Set My Low Pass Filter To? (soundcertified.com)
    3. Then watch this (but only the first 1/2, once they start answering questions its pointless)
    DSP Talk JBL DSP 4086 Five Star Car Stereo Live Stream - Bing video
    Good site for audio info home and auto Sound Certified
    Next steps are
    1. 1k Hz test tones to equalize volume at each speaker
    2. Dial in the crossover points. Soundcertified recommended 18dB slope and I started with that but ended up with 24dB slope which seemed smoother and more natural with my specific speakers. YMMV.
    3. Use white noise to set equalization.
    4. Crank it up and go deaf.
    4. ALWAYS remember that I live too far north in Spokane WA area to do long OUTSIDE Tacoma updates in the middle of winter.
    LOL
    More to come!
  17. Jan 21, 2022 at 7:10 AM
    #97
    D. Lengua
    '21 Limited LB
    i'm about to hit you with a bunch of newb questions, like: with an 8 channel dsp, why did you choose 3-ways and 2-ways?
    at whatever point you get to it, i still can't really picture the complete signal path between the various parts, HU, stock amp, dsp, etc.
  18. Jan 21, 2022 at 7:29 AM
    #98
    TacoManOne
    Paul
    Liberty Lake, WA
    I will create a diagram and post it.
  19. Jan 21, 2022 at 8:38 AM
    #99
    scootter82
    Aurora, CO
    Kenwood used to have a plug n play amp to swap out the stock JBL amp. I had it bookemarked a few years ago and cannot for the life of me find it anymore. It was still $1k+ but cheaper than the OEM solution. And if you're willing to spend $2800 pre install on that, you might as well go all aftermarket and rewire everything. Way cheaper, and not near as hard as you think
    That's what I plan on doing. Have upgraded all the speakers, and in another year or so I'll get a JBL 900/5 HD, same amp I'm using on my car's rewire. Just use 16 gauge interconnect wire to run from amp to doors
  20. Jan 28, 2022 at 7:16 PM
    #100
    TacoManOne
    Paul
    Liberty Lake, WA
    At the time I was looking for something better and was not considering an amp. The JBL DSP amp allows summing so I can send full range to any speaker so 3 way is not an issue at all.
