JBL Stereo issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Buckshot momma, Nov 28, 2022.
  1. Nov 28, 2022 at 9:24 AM
    Buckshot momma
    Buckshot momma [OP] New Member
    2016 tacoma
    I recently had a JBL Stereo installed on my 2016 Tacoma and the volume cannot be controlled by the knob nor on my steering wheel. what can be done to fix this issue? everything else works.
  2. Nov 28, 2022 at 9:38 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Need more information on what was installed. Could be a CANBUS issue. Best recommendation is to take it back to the installer.
  3. Nov 28, 2022 at 9:46 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, more info. Was it oem, or aftermarket jbl?
  4. Nov 28, 2022 at 9:48 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    More info
    Was it an OEM JBL unit installed on a non JBL system? That could be your issue, I think the JBL system was just that, an entire stream that utilized an amp that worked on a different ohm rating or something,,, hell I dunno, I’m not an audiophile.
    Maybe go back to the installer, he/she should know.
    na8rboy likes this.
  5. Nov 28, 2022 at 10:37 AM
    na8rboy
    WI
    You are correct. Whole system, can't just install head unit, utilizes 2ohm speakers w/jbl.
    Borracho Loco and Chew[QUOTED] like this.
  6. Nov 28, 2022 at 11:36 AM
    Buckshot momma
    2016 tacoma
    To be honest, I purchased it from someone who was selling it out of his 2019 Tacoma. Mine died and needed a new one. Someone mentioned I may need a non-JBL entune headunit/amp/wiring?
  7. Nov 28, 2022 at 11:43 AM
    na8rboy
    WI
    If yours was not a jbl. The jbl that's installed won't work right. If you want the jbl, you will need all other components, plus wiring harness. Ton of work.
    Chew likes this.
  8. Nov 28, 2022 at 11:52 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    You cannot install a JBL head unit in a truck that was not wired for JBL. You have to have the correct adapters and wiring harness. My JBL (it came from Toyota as the stock headunit) also has an amp, subwoofer, etc...
    Either get the proper adapters or put an original OEM head unit back in your truck.
  9. Nov 28, 2022 at 11:54 AM
    rnish
    Tacoma 2nd gen
    You may want to sell the new old HU. Start with a new aftermarket HU that integrates into your existing system.
    Chew likes this.
  10. Nov 28, 2022 at 2:07 PM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    I think @rnish advice is good. Alternatively you could call the people at Crutchfield. You might be able to get an amp that will take the output of the JBL head-unit, and convert it to line level, then boost it to work with 4ohm non-JBL speakers. They may have the harnesses and a relatively inexpensive AMP that will do the job. No hurt in asking.
