Jbl sub to aftermarket
Discussion in 'Mr Marv' started by 07txtaco, Apr 11, 2010.
  1. Apr 11, 2010 at 5:40 PM
    07txtaco
    07txtaco [OP] Member
    larry
    phx az
    07 dc taco 4x4
    i have an 07 taco doublecab with the jbl stereo installed. i want to change the sub to something that bumps just a lil bit more, can i swap out subwoofer and still use the same amp and wires that come from the amp. are there anysubwoofers that come with the same wire connection setup as the one currently installed
  2. May 14, 2010 at 7:39 PM
    JTO
    JTO Well-Known Member
    San Diego
    PreRunner Sport
    anyone?
  3. May 14, 2010 at 7:40 PM
    Scarab21
    Scarab21 Well-Known Member
    Tint, tinted tails + 3rd brake light, shaved tailgate, painted calipers. TSB Leafs+ AAL, PA/CB, 5100 Bilsteins set @ 2.5 up front. Satoshi line-x'd grill.
    yah i wanna know too!
  4. May 15, 2010 at 12:14 PM
    evil
    evil Member
    Evil
    Bakersfield, CA
    2010 PreRunner TRD Sport
    Oooooooooooooo I would like to know this also!!
  5. May 17, 2010 at 12:48 PM
    JTO
    San Diego
    PreRunner Sport
    bump
  6. May 17, 2010 at 9:04 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Bump... anybody....
    I wonder how many bumps it's going to take.
  7. May 17, 2010 at 9:07 PM
    wtbthree
    wtbthree Give 'er
    Will
    Colorado Springs, CO
    SC'ed 2010 DC
    3" Revtek lift, 17" FJ rims, 285 BFG KO's, sunroof, TRD piping, Wickedflow muffler, Avid step rails TRD supercharger,
    I have no idea, but on another note, I'd be willing to take the jbl off yer hands once it gets done
  8. May 17, 2010 at 9:21 PM
    JoeyTacoma
    JoeyTacoma Well-Known Member
    Eagle, Colorado
    2017 TRD Off-Road Pro Cement
    285/75 R16 BF Goodrich All Terrain KO2
    I am pretty sure you will need a second amp, I used a second amp to power a 10 inch JL sub and the original amp powers everything else. I took the factory sub out and put the new JL sub behind the driver side rear seat. The second amp is now where the original JBL sub was. The amp still needs to be wired to the battery but i was able to use the wire harness behind the back seat to tap into the rest of the connections. Then I but the passenger side rear seat plastic back in to cover the amps. Still have the factory jbl head unit and speaker right now they sound ok and the extra base def helps.
  9. May 17, 2010 at 9:48 PM
    JTO
    San Diego
    PreRunner Sport
    Any pictures of what your set up looks like now? I'm more of a visual learner. :help::help::help:
  10. May 17, 2010 at 10:12 PM
    JoeyTacoma
    Eagle, Colorado
    I did not take pictures when I did this, but my 10 inch sub is in it's own enclosure that was built to fit behind the back seat on the drivers side when you remove the plastic that is currently there. After I was done with the amps I put the plastic on the rear passenger side back so that still looks stock.
  11. May 18, 2010 at 4:53 AM
    JTO
    San Diego
    PreRunner Sport
    I get everything else except for this part. Are you saying that you didnt need to install a new HU?
  12. May 18, 2010 at 8:23 AM
    JoeyTacoma
    Eagle, Colorado
    I did not need to get a new head unit. There is wire bundle that plugs into the amp behind the back seat. I looked at a wire diagram and figured out what wires were for the sub and I tapped into those wires for the sub and the acc wire for the second amp, the acc wire is the one that tells the amp to turn on and off with the stereo
  13. May 18, 2010 at 11:57 AM
    JTO
    San Diego
    PreRunner Sport
    nice! i will have to take a look and see if i can figure it out.
  14. Jun 8, 2010 at 8:10 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Authorized Hybrid Audio Technologies Dealer (www.hybrid-audio.com) ARC Audio amplifiers, subs, processors now available! Helix Processors now available! For you super high end guys Brax amplifiers will be available soon! (PICS HERE and new website coming soon with Subwoofers, Amplifiers, Wiring Kits)
