JBL System Upgrade 3rd Gen Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by metalmule, Jan 10, 2022.
  1. Jan 10, 2022 at 3:13 PM
    metalmule
    metalmule [OP] Well-Known Member
    21 DCSB
    21 DCSB
    Truck came with the JBL system included.
    I upgraded the doors to the JBL Stadium GTO960C woofer.
    Dashboard upgraded to the JBL Stadium GTO20M Midrange.
    Tweeter is disconnected due to humming noise.
    Rear upgraded to the JBL GTO629 6.5.
    Subwoofer upgraded to Rockford Fosgate P3SD2-8
    Amp has been upgraded to the XR600-6DSP with maestro AR integration.
    Maestro was flashed to the 2021 toyota flash within which is a generic flash as opposed to the earlier tacoma flashes in which the vehicle specifically shows up and has more options.
    The only selection once flashed seems to be a gain if I remember correctly. But I thought the whole point of the maestro intergration was so that you wouldn't have to set a gain.
    System has noticeable distortion with certain songs over volume 30 and noticeable distortion with all songs over 35.
    Would anyone know any possible fixes? Is it simply that gain setting? Has anyone else worked with this year Tacoma and the maestro system?
  2. Jan 10, 2022 at 3:59 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    You might get an answer in the Audio & Video forum here.
    metalmule[OP] likes this.
  3. Jan 10, 2022 at 6:36 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Were all upgrades 2 ohm speakers? Besides sub and why woofers in doors?
    Jbl is very hard to upgrade, took others long time to figure them out. Few threads on the ones that were successful.
  4. Jan 10, 2022 at 6:56 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Sounds like your gains are too high. I have the same speakers and get a hiss if I turn up the gain too high on my dsp (not the amps gain)
  5. Jan 11, 2022 at 8:43 AM
    metalmule
    21 DCSB
    All the upgrades were JBL 2.5 ohm speakers besides sub. The front doors got a component set of speakers and that's just what the larger speakers that go in the door are called. The tweeter for the front is separate and has to be installed in the door sails eventually.
    Pretty sure the speakers I got would work well with the stock amp and with the current amp I have now. I've done my research and this is pretty much the best bang for the buck regarding the speakers, I'm just wondering if I got something wrong with the amp at this point.
    Recently reflashed the maestro AR unit to the generic 2021 Toyota flash and set the amp gains to "Level 3" where it was at "Level 4" before, the only other option was "Input Voltage Sensitivity" which I left at default. Lets see if it helps.
    Thanks for the input so far.
  6. Jan 11, 2022 at 3:29 PM
    metalmule
    21 DCSB
    Lowering the gain level showed no appreciable loss in distortion but a noticeable difference in volume. Still looking for a solution.
