JB's not a Broverlander build - 2004 4x4 doublecab TRD
Discussion in '1st Gen. Builds (1995-2004)' started by jbrandt, Jul 31, 2019.
  1. Oct 6, 2020 at 11:07 AM
    #81
    jbrandt
    jbrandt [OP] Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  2. Jan 29, 2021 at 4:17 PM
    #82
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    do you have a diff drop on here too?
  3. Feb 10, 2021 at 12:30 PM
    #83
    Caveman Chuck
    Caveman Chuck Well-Known Member
    2020 TRD OR DCLB
    What is a diff drop and what are the advantages?
  4. Feb 10, 2021 at 12:42 PM
    #84
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    They're spacers that lower the front of the front differential about an inch but only a percentage of that at the front axles since the rear mount of the diff remains stock.
  5. Feb 10, 2021 at 12:58 PM
    #85
    Caveman Chuck
    2020 TRD OR DCLB
    Okay, that makes sense. Thanks for the info.
  6. Mar 22, 2021 at 4:30 PM
    #86
    jbrandt
    Justin
    Sorry for the late reply, but yeah, as @Dalandser said, they are spacers that lower your diff in order to (partially) compensate for a lifted truck.
    The general consensus is that if you have more than ~2" of lift, it's a good idea to get the diff drop. It of course doesn't lower your CV angle back to stock, but it certainly doesn't make it worse, lol.
    The kits are cheap, too. Mine I think was under $30. The only problem with them is your diff will end up hitting your stock skid plate. You can get kits that include spacers for the skid, but I didn't bother since I was making a custom skid plate. In fact, at first, I just welded square stock "spacers" to my stock skid until I finished my actual skids.
    You can see the spacers here:
  7. Feb 15, 2023 at 9:26 AM
    #87
    B.rad31
    B.rad31 Member
    Brian
    2002 Toyota Tacoma 4x4 v6 (manual)
    what was the cause of the squeaking and popping sound because i have that too?
