JBTacoma 1st Gen Stress Reliever
Discussion in '1st Gen. Builds (1995-2004)' started by JBTacoma, Aug 17, 2015.
  1. Dec 21, 2015 at 5:23 AM
    #41
    JBTacoma
    JBTacoma [OP] Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Installed LED lights under the rear bumper.
  2. Dec 22, 2015 at 6:45 PM
    #42
    JBTacoma
    Jeff
    Cullman Alabama
    My son installed my winch for me today.
  3. Dec 30, 2015 at 12:03 AM
    #43
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    SO how did you end up mounting the center console because I tried today and realized the mounting was different bu I have parts from my totaled 04 that I could use! Just wondering how you did it! Also do you have any pics of the frame caps welded on? Did you buy the frame caps or make some? And last, how much did you cut off the frame horns? Thanks a lot!
  4. Dec 30, 2015 at 8:05 AM
    #44
    JBTacoma
    Jeff
    Cullman Alabama
    Had to use the bracket that came from the truck that the console came from. Below is a picture of the bracket that was in my truck. Just use the bracket from your donor truck.
    I don't have any pictures of the end caps welded on but below are some links I used to help me. Also attached a couple pictures from another site that shows what mine also looked like when welded on.
    http://www.nwtoys.com/content/123-frame-endcap-modification.html
    https://www.tacomaworld.com/threads/1st-gen-diy-bumper-write-up.307633/
    https://www.tacomaworld.com/threads/frame-end-modifications-for-1998-2000-tarightcomas.268141/
    http://www.expeditionportal.com/forum/threads/113203-1st-Gen-Endcap-Mod
    https://www.tacomaworld.com/threads/tipicotacos-rad-baron-01-dc.335684/#post-8881946
    In the picture below you can see where the bolts go on the bottom of the frame and the end cap. Measure from the center of the hole to the end cap on your bumper (between the red lines in the picture), then measure from the center of the bolt hole on the truck frame and mark the same distance on your frame. That will be where you need to cut it. Bought a piece of 1/4 flat bar and made some plates. Make sure you weld the plates inside the frame and not on the end. If you add them to the end it will add a 1/4 inch in length and they will be too long or cut an extra 1/4 off the frame and then weld them to the ends.
    Also the hole in the center of the end cap is off center left to right. The hole is centered from top to bottom. Make sure you measure your end caps and get the hole where it needs to be. There is a picture showing the end cap below. The holes are off center to the inside if you look at them from the front of your truck. I also welded the bolts onto the plates before welding them to the frame. Some people weld nuts on the end caps but I used bolts, that way you can set the bumper on the bolts sticking out when you are installing the bumper, just makes the install easier.
  5. Dec 30, 2015 at 1:01 PM
    #45
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    For 98-00s you were supposed to cut 3 inches off the frame horns, which includes the stock skid plate location. Just an FYI for the future for anyone looking at this. But if yours works I'd leave it
  6. Dec 30, 2015 at 1:49 PM
    #46
    JBTacoma
    Jeff
    Cullman Alabama
    3 inches was not enough for me and it depends on where you weld the end plate. If you slide the plate inside the frame to weld it or weld it to the end of the frame? If you weld it to the end of the frame it also depends on the thickness of the metal you use.
    I think it is best to measure your bumper and frame and not just assume it is 3 inches. If you weld the plate on and it is too long, the holes on your bumper will not line up and you will have to redo the end caps.
  7. Dec 30, 2015 at 8:50 PM
    #47
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yea true, I did about 3 inches plus the thickness of my plate I was provided and it lined up pretty good. But it's best to take everything off and measure where you need to cut
  8. Dec 30, 2015 at 9:02 PM
    #48
    TacoVio
    Kolton
    CO/WY
    Where did you guys get the frame caps? Make them?
  9. Dec 31, 2015 at 7:17 AM
    #49
    JBTacoma
    Jeff
    Cullman Alabama
    Bought a piece of 1/4 flat bar and made the plates. Got a piece of 3 inch X 1/4 and cut off a piece big enough to cover the end of the frame.
    You can get a piece at your local machine shop, Tractor Supply, Lowe's...
    TacoVio[QUOTED] likes this.
  10. Dec 31, 2015 at 11:15 AM
    #50
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I had the manufacturer of my bumper make it. So that's the route I'd go
  11. Dec 31, 2015 at 12:26 PM
    #51
    TacoVio
    Kolton
    CO/WY
    Just make the squares? Did they just weld bolts to the back of it?
  12. Dec 31, 2015 at 1:08 PM
    #52
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Basically! But it's easier to weld the nuts at the back I think. Not sure, mine have the nuts at the back
  13. Dec 31, 2015 at 2:51 PM
    #53
    JBTacoma
    Jeff
    Cullman Alabama
    You can weld nuts or bolts, as posted earlier it makes it a little easier if you weld bolts it gives you something to hang the bumper on while you put all the other bolts in. The links posted earlier shows you how to do everything.
  14. Jan 21, 2016 at 1:53 PM
    #54
    JBTacoma
    Jeff
    Cullman Alabama
    Got my Hella's today, waiting on the 55w HIDs to put in them.
    buckmaster243 likes this.
  15. Jan 26, 2016 at 7:02 PM
    #55
    JBTacoma
    Jeff
    Cullman Alabama
    Found this switch in a 4runner at Pull-A-Part used it for the Hella 500's
    TrailRider2002 likes this.
  16. Feb 22, 2016 at 6:06 PM
    #56
    badmotofing3r
    badmotofing3r Member
    Zach
    Great looking build.
  17. Feb 22, 2016 at 7:20 PM
    #57
    JBTacoma
    Jeff
    Cullman Alabama
    Thanks
  18. Feb 23, 2016 at 7:14 PM
    #58
    JBTacoma
    Jeff
    Cullman Alabama
    Got a set of 510s today.
  19. Feb 28, 2016 at 5:14 PM
    #59
    JBTacoma
    Jeff
    Cullman Alabama
    Got the PIAA 510s installed in the bumper...
  20. Feb 29, 2016 at 2:49 PM
    #60
    JBTacoma
    Jeff
    Cullman Alabama
    Got some parts from 4Wheel Parts to extend my winch controls to inside my cab.
