**Closed** JD Fab Inner fender GB
Discussion in 'Automotive Group Buys' started by ovrlndkull, Apr 20, 2022.
  1. Apr 20, 2022 at 2:20 PM
    ovrlndkull
    ovrlndkull [OP] STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Ok so talking with Harry he wants to run another Inner fender GB. There are some changes compared to their last GBs so PLEASE read carefully.
    DISCLAIMER READ ENTIRE POST(S) BEFORE COMMITING!!!!!!!!!
    What:
    This is a group buy for the innner fenders for JD fabrication. Must get at least 10 and pricing gets better at 20
    What you get:
    With the inner fenders you'll get a free battery tray (149.99 value) 2 to choose depending on your battery on top of a discounted price of the inner fenders.
    Battery tray sizing is as follows LG for stock battery SM for those running a group 34ish size optima or odyssey size.
    Retail for the inner fenders is set at 1999.99
    Battery tray 149.99
    10 people commit pricing will be 1700 + shipping
    20+ people commit pricing will be 1500 + shipping
    Time frame:
    The group buy will be running from 4/20-5/20
    Lead time:
    For this GB there will be a lead time of ~4-5 weeks post close of the GB no way around it.
    Your Obligation:
    When you go in on this that is your OBLIGATION to buy. Kinda like when you place an order online. If you are sitting on the fence or need to work out monetary stuff do not go in until you are 100% ready. We don't want to be adding and taking names off this GB everyday. In other words make sure all your ducks are in a row before going in.
    When you commit I need to know size of battery tray. I do not need to know if you have a 2nd or 3rd gen
    Things to be aware:
    This is not just a bolt on application you need to be or have a shop that is proficient at cutting and fitting to cut the old ones out and line up and attach the new ones to your firewall and core support. This is more geared to the guys really pushing the limits of IFS on the tacos. Once you cut out all the old this does bolt in and together. There have been a lot of guys do this outside in their backyards or garages. It can be done it's not hard but not easy either.
    What this solves:
    So the inner fenders solve rubbing issues of the inner fenders with larger tires. This mates well with the Lower pivot and/or LT kits from JD as they move the tire forward of the firewall and the inner fenders allot more room towards the front for that. They have a significant increase in space for the tire up and in the back as well. They also allow more up travel. 35s definitely fit, 37s may fit but there are a lot of variables for that. With the JD LT and the increased up travel that the kit gives you this is definitely a plus instead of having to hack and tub your weak stock inner fenders.
    These fit 2nd and 3rd gen tacomas pictures show both!
    If you have questions you can look through the main JD thread here https://www.tacomaworld.com/threads/fitting-35’s-with-minimal-trimming-now-adding-long-travel-and-934-cv’s.626274/ to see if you can find your answer, if not post them there or here. I'd like to keep only questions geared towards the GB here tech questions in the JD thread please and thank you.
    Here is a link to the website https://jdfabrication.com/collections/05-15-6-lug/products/tacoma-inner-fender-replacements
    Some things have changed to simplify and ease in shipping but not sacrifice strength.
    More technical questions here I'm sure @81Trekker can answer or @Airdog (he was the install test dummy).
    nudavinci64, CygnusX191 and Brian422 like this.
  2. Apr 20, 2022 at 2:21 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Jerez and CygnusX191 like this.
  3. Apr 20, 2022 at 2:21 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    also mine
    CygnusX191 likes this.
  4. Apr 20, 2022 at 5:00 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Yes. Was about to order and just talked to Jesse about it. So if I can save a few. Hells yea!!
    CygnusX191 and ovrlndkull[OP] like this.
  5. Apr 20, 2022 at 5:02 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Wow. Looks amazing. Will have to save up.
  6. Apr 20, 2022 at 5:02 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Jesse let you know to be patient and wait a little huh? They really are a class act there.
  7. Apr 21, 2022 at 9:17 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Bumpity bump. Those of you with the IG let your buddies know tell them to get in contact with me and I'll get them squared away
  8. Apr 21, 2022 at 12:38 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Hmmm
  9. Apr 21, 2022 at 12:40 PM
    Oreo Cat
    Anyone out there running a stock length setup with these and 37s?
  10. Apr 21, 2022 at 4:27 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Not sure but you may need to modify some. @81Trekker may have some insight. Having them in hand I will say that if needing to modify to allow for bigger tires will be a hell of a lot easier and far stronger than the oe crap.
  11. Apr 21, 2022 at 5:20 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Do you have the lower arms pushed forward?
  12. Apr 21, 2022 at 6:30 PM
    Oreo Cat
    I will, I have a growing parts pile
    6112s
    Your LCA Pivot kit
    And your .25 arms on the way
    not sure if I should do the inner fenders or have a custom job done, I like your design more and am ok with some trimming of it, but would rather not completely butcher a set of them
    nudavinci64 likes this.
  13. Apr 21, 2022 at 6:38 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Hmmm tapped out from recent stuff but missed the last one! Very tempted
    ovrlndkull[OP] likes this.
  14. Apr 22, 2022 at 12:17 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    throw me on the list; I messed up on the last group buy...wife wont know :laugh:
    Also for local pick up; I frequent SD county for work all the time so i can swing by on my way back from a job.
    ovrlndkull[OP] and doublethebass like this.
  15. Apr 24, 2022 at 6:10 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    bump fellas
  16. Apr 26, 2022 at 2:03 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    TTT lets get this thing done so ya'll can get a good discount
  17. Apr 27, 2022 at 2:34 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
  18. Apr 28, 2022 at 3:04 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    bump fellas and ladies
  19. Apr 28, 2022 at 2:25 PM
    nudavinci64
    Robert
    il likely know more next month after a few things settle. Also looking at the Howe setup
  20. Apr 28, 2022 at 2:33 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I can swing half off and pay in july :anonymous:
