Jd fab or dirt king rear spring under question
Discussion in 'Long Travel Suspension' started by xx3xil3xx, Mar 18, 2022.
  1. Mar 18, 2022 at 9:19 PM
    xx3xil3xx
    xx3xil3xx [OP] Well-Known Member
    ESCONDIDO/SAN DIEGO, CA
    06 runner
    Looking in to both kits and just wondering if anyone here ran the jd fab kit? Benefit of rear shackle difference besides it doesnt hang as low as the dirt king?
  2. Mar 19, 2022 at 9:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Mar 25, 2022 at 2:27 PM
    tymebandit951
    tymebandit951 Well-Known Member
    Boise, ID
    2013 4x4 DCSB
    If there's one thing I've learned with my stupid truck is that I should have just started with JDs stuff from the beginning. And that's not to say that Dirt King doesn't make good stuff. Nick and the boys at DK make great products, I think JD just thinks of things that other people don't.
    llibrm, 01 dhrracer and xx3xil3xx[OP] like this.
  4. Apr 1, 2022 at 3:04 PM
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    Just waiting on my rear shocks from JD fab and than it's install time for me. Honestly their shock tower design and rear shackle set-up is what sold me you still have a usable bed and less to get hung up on just an all around win win for me.
    01 dhrracer likes this.
  5. Apr 1, 2022 at 3:17 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Tyler Lacasse and snowsk8air2 like this.
  6. Apr 12, 2022 at 6:32 PM
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    I'm running the JD SUA kit but just the spring hangers. Three main points that sold me was the shackle orientation, uniball shackle, and adjustability of the rear hangers. No complaints so far; exactly what I expected.
    Marcgb91 and llibrm like this.
  7. Apr 14, 2022 at 3:49 PM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    Are you using the spring hangers with a soa setup then? I was thinking about doing something like that if it's possible.
  8. Apr 14, 2022 at 7:39 PM
    Adventure4x4
    Adam
    San Antonio, TX
    No, I'm using the deaver H70 as a spring under setup. You could use Chevy 63s if you wanted to do SOA.
  9. Apr 14, 2022 at 8:10 PM
    bhigbee
    Barney
    Hayden Id
    Wrecked 07 DCSB
    I have a set of Deaver U402 stage 2s now but I wouldn't mind changing the shackle.
  10. Apr 14, 2022 at 8:38 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    We have Deaver spring over springs if that’s your thing
    bhigbee[QUOTED] likes this.
  11. Apr 15, 2022 at 5:21 AM
    bhigbee
    Barney
    Hayden Id
    Wrecked 07 DCSB
    Thanks Harry, I'll get my crawl box in and then give you a call about the rear kit and the steering pump. They're both on my list.
  12. Dec 7, 2022 at 9:54 PM
    TRDProDriver
    TRDProDriver Member
    Thread revive—
    Just to clarify, can the JD shock relocation towers be used on a SOA? @81Trekker
  13. Dec 18, 2022 at 8:10 AM
    Camazon
    Camazon Well-Known Member
    Cam
    Vancouver,BC
    06 Tacoma TRD Off Road DCSB
    No reason why not. You would just have to adjust the lower shock mount on the axle.
  14. Dec 18, 2022 at 8:24 AM
    81Trekker
    La Jolla SD
    The shock mounts are designed to allow the axle to bump on the frame with a 14” shock. If you are SOA then you will have 5-6” less uptravel. This means you could run a 16” shock or mount the 14” shock off the top of the axle with long tabs
  15. Dec 18, 2022 at 5:08 PM
    TRDProDriver
    TRDProDriver Member
    A 16” shock for SOA—that’s a lot of shock, albeit with less overall uptravel. I understand overall my HD SOA spring pack only has about 12” of travel at it’s limit, so maybe the 14” shock should be what I need to aim towards. Am I thinking things through correctly in that I wouldn’t need limit straps then since my leaf pack would essential be the limit and would be protecting my shocks from bottoming out?
  16. Dec 18, 2022 at 5:53 PM
    81Trekker
    La Jolla SD
    Correct your springs will be the limiting factor. Our shock mounts are designed to allow the axle to bottom out on the frame with a 14” shock. When you limit the uptravel with a SOA you can use a longer body shock (16”) and the shock won’t bottom out. Obviously the 16” shock has more stroke than you will use but you have the option
  17. Dec 18, 2022 at 11:08 PM
    TRDProDriver
    TRDProDriver Member
    And I love having options! Are the 1/4” formed shock towers made from cromoly?
  18. Dec 19, 2022 at 6:26 AM
    81Trekker
    La Jolla SD
    The towers are mild steel, 1/4” cromoly can’t really be formed with the dimensions the towers have… the material will crack at the corners.
  19. Dec 19, 2022 at 9:37 AM
    TRDProDriver
    TRDProDriver Member
    Good to know! So does install of the towers require the bed to be removed or can the bed stay on?
  20. Dec 19, 2022 at 10:06 AM
    81Trekker
    La Jolla SD
    You can do it with the bed on
    llibrm likes this.
