JDawg562's Long Travel Tacoma
Discussion in '2nd Gen. Builds (2005-2015)' started by JDawg562, May 6, 2014.
  1. Jan 29, 2018 at 9:28 PM
    #221
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    o_OBumped and strapped?
    Honestly never checked at the hub lol.
    The front 8" coilover I have ~4 1/4"" up and ~3 1/4" down. Bumped about 1/4" before coilover bottoms out and strapped about 1/4" before it fully extends. Not sure what that works out to at the tires. Total chaos says 13" of travel with 4WD and I'm a 2WD.
    The rear has a 16" smoothie ~7" up, ~9" down my rear. bumped 1/4" before shock bottoms out not strapped yet. Ordering one this week.
    mcharfauros likes this.
  2. Jan 29, 2018 at 9:35 PM
    #222
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I was more wondering about the driveshaft lol
    So many doublecab solutions, but not enough access cab info, so I jump at the opportunity to get some correct measurements
    BassAckwards likes this.
  3. Jan 29, 2018 at 10:00 PM
    #223
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Ah yeah I know...
    So I took measurements randomly (what I thought was correct) transmission face to center of carrier bearing to bolt on pinion at ride height, droop and compression. I took my drive shaft to a shop and gave them the measurements, but they wanted measurements from carrier bearing bolt on one side to pinion flange same side. So I went home got the measurements at the passenger carrier bearing bolt to passenger side middle of the pinion flange at ride height, droop and compression. Then called them back with those measurements and they cut it down and added I believe a 6" slip yoke which was more than enough. I think at the max distance to minimum distance was about 1.5" of movement needed. The shop does "normal vehicles" as well as crawlers/rock bouncers/custom, so they actually had a clue what I was talking about lol.
    I can give you my ride height and droop measurements tomorrow, but Tim from DMZ said the measurements can be different.
    MrCrowntown[QUOTED] likes this.
  4. Feb 10, 2018 at 11:09 PM
    #224
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Bump Stops and Spindle Gusset
    I might change the front bump stop mounts down the road, but here's where it's mounted for now. @TacomaGuy23
    Spindles Gussets!
    I welded as much as I could on the front and stitch welded down the back and fully at the top and bottom. I also did a little grinding at the bottom to keep the stock brake dust guard in without it hitting.
    Bonus
    Since I had a spare floor jack. I deiced to do a "sub frame lift" with scrap angle iron and some heavy duty wheels I bought off Amazon. Works good I can lift the entire front half of my truck with it under the engine. All the wheels are rated to 4800lbs or 2.4 tons. Best of all no more dragging out blocks to put on the floor jack plate and I can lift my truck on gravel/dirt/cracked/uneven driveway without the truck trying to slip off. I always use jack stands... I don't like trusting floor jacks with a $0.05 o-ring holding it up when any part of my body is under it.
    From harbor freight:
    Maximum Lift Height (in.) 19-1/2 in.
    Minimum height (in.) 2-7/8 in
    After:
    Maximum Lift Height (in.) 26 in.
    Minimum height (in.) 9-3/8 in
  5. Feb 12, 2018 at 9:10 AM
    #225
    TacomaGuy23
    TacomaGuy23 Well-Known Member
    Cody
    Fullerton, California
    2014 Tacoma Double Cab Prerunner
    Dirt King Long Travel, URD Supercharged
    :thumbsup:
  6. Feb 16, 2018 at 12:01 AM
    #226
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Made some remote reservoir mounts out of scrap angle iron and 1/8" steel plate after work. No longer bouncing around rattling and the hose clears the springs by about 1/2"
    [​IMG] [​IMG]
  7. Feb 17, 2018 at 12:47 PM
    #227
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
  8. Feb 22, 2018 at 2:55 PM
    #228
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Finally bought a nitrogen refill station!
    mcharfauros and Dalandser like this.
  9. Feb 23, 2018 at 9:24 PM
    #229
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    lol I'm instagram famous!:bananadance: What's your instagram?
    TacoLean likes this.
  10. Feb 23, 2018 at 10:07 PM
    #230
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Me too!
  11. Mar 19, 2018 at 10:23 PM
    #231
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Forgot to post this here.
    I stopped at Barstow on the way back from The Mint 400 and tested my new valving real quick.
    It has basically a .012 stack in there on compression.
    https://www.youtube.com/watch?v=SySdcUok59w
    Compression Valving
    [----Piston----]
    ------------.012
    ----------.012
    ----.010
    -------.012
    ----.012
    ---0.12
    I'm happy with it. I also ordered an AAL for the DMZ pack. Just waiting for them call me so I can pick it up and I'll toss it in.
  12. Apr 4, 2018 at 3:53 PM
    #232
    bren5279
    bren5279 Well-Known Member
    Brendon
    new bern NC
    2012 Black Tacoma TRD Long Travel Supercharged
    TRD Supercharger Dirt King 14" Long Travel Kit Pro Comp 6" lift Fox dual rate 2.5" remote res front coil carriers Fox triple bypass 2.5" remote res front shocks Fox 12" 2.5" Remote Res. Shocks DSC adjusters (flutter shim stacks) ARB Lockers F+R 4.88 Regear F+R Shackle flip kit Bamf tall shock mount Demello Offroad Front Bumper Smittybilt Winchs F+R Method beadlock 17x9 Rims 37" Open country R/T tires Baja fiberglass Front Fenders Baja Fiberglass Rear Fenders Bulletproof Fab Front Grill Air Intake Reroute High Lift Jack Pro Comp Skid Plate KB Voodo Short Bed Rack CVT Cascadia Rooftop Tent
    Hey fantastic looking taco man, Quick question though; I saw you went from the Mts to the Rts. How's the difference? Was looking at both of those tires for my LT setup but Im worried the RTs won't handle sand or mud well
  13. Apr 4, 2018 at 5:16 PM
    #233
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Well with the M/Ts I bought them used what lowish tread and the previous owner wore them out unevenly. It was more of a $400 test to see if 35s would fit before I actually buy new ones. I've only actually been stuck once in a pit of mud that was at least a 1' deep, sticky, thick and every direction was up hill... The Toyo M/Ts were also the quietest mud tires on the street I've used too. They could compete with some "louder" A/T tires.
    The Toyo R/Ts for me are prefect for me. Maybe just a tad overkill for my driving. I learned what I can/can't do and don't really push the limit of my RWD truck getting stuck or not. Most friends also only have A/T tires, most only have 32s tires max, only a couple of them have 4WD and a couple of them don't have locking diffs either.
    Both are/were 35s, load rating E, heavy and stiff side walls. They both were also the best in wet street conditions out of the other M/Ts tires I used too.
    I only recently started playing with tire PSI since I bought a portable compressor that also helps a ton wish I did that sooner.
    These are my first time using Toyos on anything and I'm really happy with them both, but for my style of driving and the amount of miles on street vs dirt I chose the R/Ts.
  14. May 25, 2018 at 11:17 PM
    #234
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
  15. Jun 8, 2018 at 9:29 PM
    #235
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Had a few days off and decided to make a bumper.
  16. Aug 4, 2018 at 8:53 PM
    #236
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
  17. Aug 4, 2018 at 8:56 PM
    #237
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol flipping you're spare like a coin - looks good though.
    JDawg562[OP] likes this.
  18. Aug 4, 2018 at 9:13 PM
    #238
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    lol yeah I looked in my rear view mirror and was like "ohhhhh shittttt". Still thinking about building a mount to actually use lug nuts to bolt it on, but lately been on the fence about taking out my bed liner and actually welding a bed cage on to the frame.
  19. Aug 26, 2018 at 11:28 AM
    #239
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Wishbone Runner likes this.
  20. Aug 26, 2018 at 11:40 AM
    #240
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
