JDMCQ's Garage
Discussion in 'Off-Topic Discussion' started by JDMcQ, Jul 26, 2009.
  1. May 5, 2012 at 10:04 AM
    acdronin
    acdronin Well-Known Member
    No knots
  2. May 5, 2012 at 10:05 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Another option I've used before on really hard ground is drill into the ground along side the box with a hammer drill and pound in 5/8" rebar pins .
    Just make sure to leave them lower than the box top and make sure to dull the tops
  3. May 5, 2012 at 10:06 AM
    OZ-T
    Peter North
    British Columbia
    Clear
  4. May 5, 2012 at 10:07 AM
    acdronin
    I did two boxes for a client last year, a 4'x10' and a 4'x12', i drove 3/8 lag screws into the sides to the posts, i treated the cut ends of the redwood.
  5. May 5, 2012 at 10:08 AM
    acdronin
    It's called by both terms down here
  6. May 5, 2012 at 10:09 AM
    acdronin
    LOL, yeah, I like my projects over-engineered:D
  7. May 5, 2012 at 10:10 AM
    OZ-T
    Peter North
    British Columbia
    Just build a box from 2" thick cedar or redwood to the height you want and chuck it on the ground and fill with dirt
    That will work
  8. May 5, 2012 at 10:12 AM
    OZ-T
    Peter North
    British Columbia
    I would suggest predrilling and using long screws to build the box , less likely to pull apart when someone uses the box as a lever for the shovel or pitchfork
  9. May 5, 2012 at 10:14 AM
    OZ-T
    Peter North
    British Columbia
    Cedar and redwood are naturally rot resistant because of the naturally occuring oils and tannins in them , pine is terrible for that
  10. May 5, 2012 at 10:15 AM
    acdronin
    x2
  11. May 5, 2012 at 10:20 AM
    OZ-T
    Peter North
    British Columbia
    can you ? Yes
    Would I ? No
  12. May 5, 2012 at 10:23 AM
    OZ-T
    Peter North
    British Columbia
    Can you ? Yes
    Would I ? No
  13. May 5, 2012 at 10:23 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    X2 on the redwood. I had a redwood deck for almost 20 years and decided to remove it. I used the removed redwood to build a treehouse for my son.
    Another nice wood to use is yellow cedar. Due to the fiberous nature of the wood there are no splinters.
    If I look out in my small shed I still have some clear all heart redwood 1X4 pieces of wood left over.
  14. May 5, 2012 at 10:23 AM
    OZ-T
    Peter North
    British Columbia
    X2
  15. May 5, 2012 at 10:24 AM
    OZ-T
    Peter North
    British Columbia
    Yellow Cedar is actually a Cypress and not a true cedar and it lacks the rot resistant qualities of Western Red Cedar
    Little known fact :)
  16. May 5, 2012 at 10:33 AM
    OZ-T
    Peter North
    British Columbia
    No washing machine at home ?
  17. May 5, 2012 at 10:34 AM
    DrewH
    DrewH Well-Known Member
    laundromats suck
  18. May 5, 2012 at 10:54 AM
    acdronin
    Can't stand Cypress, messy, ugly trees
  19. May 5, 2012 at 11:07 AM
    MTgirl
    Weesa
    Bob's secret mod lair
  20. May 5, 2012 at 11:16 AM
    OZ-T
    Peter North
    British Columbia
    OZ has used composite material before and he never will again
    It's garbage , literally .
    It's ground up sawdust and garbage bags , I don't know how it got it's " eco friendly " label as all it is , is garbage making one more stop on it's way to the landfill .
    At least wood is renewable
