JDMCQ's Garage
Discussion in 'Off-Topic Discussion' started by JDMcQ, Jul 26, 2009.
  1. Sep 1, 2012 at 1:00 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Ethics be with you
  2. Sep 1, 2012 at 1:01 PM
    OZ-T
    Peter North
    British Columbia
    Check the torque of the bolts , should be at 100 ftlbs
    Before you touch them , mark the alignment cam locations
    Check for signs of movement at the cam bolt heads or flattening of the cam tabs
  3. Sep 1, 2012 at 1:04 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    I will. But I knew they were seized beforehand, just didn't know it would cause that noise. I was just mainly going to track down the noise itself. Maybe after the winter I will take the lowers off and press out the bushings. I saw the alignment shop torque em after they were done..
  4. Sep 1, 2012 at 1:10 PM
    OZ-T
    Peter North
    British Columbia
    Ah
    Well if the bolts are seized to the sleeves in the bushing , the movement of the LCA's can mangle your cam tabs
  5. Sep 1, 2012 at 1:16 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    They had to torch em to get my alignment in. Damn Toyota and their lack of grease. I will go out in a bit and look at the tabs.
  6. Sep 1, 2012 at 1:20 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Not Nm? :confused:
  7. Sep 1, 2012 at 1:22 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  8. Sep 1, 2012 at 1:22 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  9. Sep 1, 2012 at 1:24 PM
    MTgirl
    Weesa
  10. Sep 1, 2012 at 1:25 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    How did I know you would be a linkin park fan?
  11. Sep 1, 2012 at 1:27 PM
    MTgirl
    Weesa
    Me? Or Dino boy?
  12. Sep 1, 2012 at 1:27 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    The extinct one.
  13. Sep 1, 2012 at 1:54 PM
    Round II
    Round II Member #12005
    Thats the plan yea.
  14. Sep 1, 2012 at 1:56 PM
    Round II
    Just the one you lent me which by the the way can fit like 3 of me in.:eek:
  15. Sep 1, 2012 at 2:02 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    Oz, found which one is seized. I have one that has pushed the alignment tab over (not flat though). It is tight, so I don't know how it got that far out of place without flattening the tab. I guess I can drive around a bit with it like that... Just need to watch my tires I guess.
  16. Sep 1, 2012 at 2:04 PM
    OZ-T
    Peter North
    British Columbia
    Thing is , when the bolt is seized in the sleeve , the bolt twists / moves with the LCA , this is the sound you hear
  17. Sep 1, 2012 at 2:06 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    I knew that, just trying to figure out how the alignment cam came outside of the tab without flattening it instead. Eh, I can't really grease it at the moment so I put a bit of the fluid film in/around it. Maybe it'll help, but doubtful.
    Just glad I only have one bushing that is seized. One out of 4 isn't bad.
  18. Sep 1, 2012 at 2:07 PM
    Round II
    Good luck on the removal if you have to. I had to cut mine off do to being fused with the LCA. While I was at replacing the tabs for an alignment I went ahead and just replaced the whole LCA.:D
  19. Sep 1, 2012 at 2:09 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    I wish I could just find a way to crack the LCA's and tell toyota to replace them. I am still under warranty for 2 months. Too bad the bushings aren't considered a warranty item.
  20. Sep 1, 2012 at 2:22 PM
    DrewH
    DrewH Well-Known Member
    :eek:
