JDMCQ's Garage
Discussion in 'Off-Topic Discussion' started by JDMcQ, Jul 26, 2009.
  1. Sep 12, 2012 at 7:27 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    E-brake light keeps coming on. Only when its cold (parked outside overnight) once it warms up to normal operating temp the light goes out.
  2. Sep 12, 2012 at 7:28 AM
    krap22
    krap22 Well-Known Member
    deal with it. My '99 was really flaky with the e-brake light.
  3. Sep 12, 2012 at 7:28 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Sep 12, 2012 at 7:30 AM
    MTgirl
    Weesa
    no :mad:
    :mad:
  5. Sep 12, 2012 at 7:35 AM
    MTgirl
    Weesa
    :mad: stop that
  6. Sep 12, 2012 at 7:38 AM
    JDMcQ
    JDMcQ [OP] Well-Known Member
    The Mushroom Capital of the World
    Thank you. I knew I was going to forget to block that out.
  7. Sep 12, 2012 at 7:39 AM
    JDMcQ
    You did not lube the lever correctly. Operator error.
  8. Sep 12, 2012 at 7:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    That doesn't help. Is the handle loose? Did you do anything to the truck that I suggested?
  9. Sep 12, 2012 at 7:49 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Same here with my 97. I eventually didn't notice the light, but it took a while. I kind of doubt Lisa will be able to live with the dash light. Remember, she has to have the number of lug nuts match the wheel pattern. :D
  10. Sep 12, 2012 at 7:50 AM
    DrewH
    DrewH Well-Known Member
    :laughing:
  11. Sep 12, 2012 at 7:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's a simple fix guys.
  12. Sep 12, 2012 at 7:59 AM
    MTgirl
    Weesa
    its only for a few minutes - i doubt that any condensation would evaporate in that time.
    :mad: hush
    :mad: yes - i sprayed everything down with PB last night. The mech at the rears moved easily enough and theres another lever along the frame just rear of the cross member, that was a little stiffer so I lubed it up too.
    :mad: now you're making fun of me too?!?! Dave....:(
  13. Sep 12, 2012 at 8:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    Your rears might need adjusted. Do you use the parking brake?
  14. Sep 12, 2012 at 8:03 AM
    MTgirl
    Weesa
    :eek: There is nothing wrong with my rear end Mister!
    Rarely - if I'm parked on an incline I will use it otherwise no.
  15. Sep 12, 2012 at 8:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Start using it for a week...it's what adjusts the rear brakes. ;)
    I wouldn't know anything about your tush...why does everything have to be sexual with you?
  16. Sep 12, 2012 at 8:07 AM
    JDMcQ
    Listen to Ben, he is very wise. You will have to work the parking brake to free up those lever joints underneath too.
  17. Sep 12, 2012 at 8:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    You said "work it" ..huuuh ...huh huh...huh..
  18. Sep 12, 2012 at 8:11 AM
    JDMcQ
    You are welcome, I appreciate your support.
    *snicker*
  19. Sep 12, 2012 at 8:20 AM
    MTgirl
    Weesa
    Fine :mad: I will try using hte brake for a few days
    :mad: Brown noser
    :smack: Stop quoting the pics!
    :facepalm:
  20. Sep 12, 2012 at 8:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    Typical...
    Pateince is not your strong suit
