JDMCQ's Garage
Discussion in 'Off-Topic Discussion' started by JDMcQ, Jul 26, 2009.
  1. Jun 19, 2013 at 2:10 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    :eek: how on earth did the water get in the tank? I can't imagine you guys are the only ones having issues...gonna be a lot of angry customers at that station...
  2. Jun 19, 2013 at 2:13 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    How can you keep dogs from pooping in their kennel when even they don't care that they poop in their kennel?
    Not my dog, they're my girlfriend's chihuahuas.
  3. Jun 19, 2013 at 2:13 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    We'll find out... :rant:
  4. Jun 19, 2013 at 2:21 PM
    MTgirl
    Weesa
    doggie diapers :notsure:
    :popcorn:
  5. Jun 19, 2013 at 2:22 PM
    scocar
    scocar hypotenoper
    This is a common problem with chihuahuas. The commonly accepted method to correct it is to kill them.
  6. Jun 19, 2013 at 2:23 PM
    krap22
    krap22 Well-Known Member
    how big is the kennel? Dogs should have just enough room to turn around and lay down. If it is too big, they will poop/pee in one area and go lay down in another area.
  7. Jun 19, 2013 at 2:26 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
  8. Jun 19, 2013 at 2:28 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    When gas is delivered to the station there is sediment and water in the underground tank. The filling of the underground tank stirs up the sediment for up to two days and you pump it into your vehicle's tank. A 45 to 55% ratio is very high. I would say the tanker had contaminated gas when they filled up the stations tank. There should be a lot of complaints about the gas at that station.
  9. Jun 19, 2013 at 2:33 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    hmmm.... possible....
    If the girlfriend wasn't so attached, trust me, I would have.... uh... "found them a new home" a while ago
    We put two to one kennel, one's about 10 lbs, the other about 6. They both sleep and spend the day while we're at work in what's essentially a rabbit cage.
  10. Jun 19, 2013 at 2:36 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Me want
  11. Jun 19, 2013 at 2:36 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    This. Not sure who you should report it to Craig but I would find out and do so. That's just crazy. Any chance it was some dipshit kids? Got locking cap?
  12. Jun 19, 2013 at 2:37 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    Reason #2 why that was my first "mod"
  13. Jun 19, 2013 at 2:41 PM
    XXXX
    sKiP
    05 Prius
    I need to do it when I get me new engine in. Not sure what happened to my first but i wouldn't doubt foul play.
  14. Jun 19, 2013 at 2:42 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    Id blame your current nemesis
  15. Jun 19, 2013 at 2:42 PM
    MTgirl
    Weesa
    i know that there are sediments and stuff in the tanks too but aren't they cleaned out every so often to try to keep it to a minimum?
    hmmm...Homer...were your kids playing around the cars? pretend gas station with a garden hose?
  16. Jun 19, 2013 at 2:43 PM
    scocar
    scocar hypotenoper
    It's possible with that amount that the UST has failed (corrosion or otherwsie) and groundwater is leaking into it.
    Craig, the state should have a UST regulating body you can look up for more info on owners' responsibilities, etc., and where to file complaints or need for investigation.
  17. Jun 19, 2013 at 2:45 PM
    scocar
    scocar hypotenoper
    They should all have sumps along with filters between the tank and pump that are serviced regularly. Assuming whatever station is keeping up with maintenance.
  18. Jun 19, 2013 at 2:46 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    Best $15 I ever spent:D
  19. Jun 19, 2013 at 2:49 PM
    XXXX
    sKiP
    05 Prius
    Lol nope. The derp was not unleashed 6 months ago when it started + I got great looky loo neighbors and live on a court. Whenever someone pulls in the one old lady stares out her window.
  20. Jun 19, 2013 at 2:57 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    Sounds almost like my street. Hope my new place is just as good
