JDMCQ's Garage
Discussion in 'Off-Topic Discussion' started by JDMcQ, Jul 26, 2009.
  1. Jul 2, 2010 at 7:47 AM
    JDMcQ
    JDMcQ [OP] Well-Known Member
    The Mushroom Capital of the World
    I believe that she is making a dry set, brick paver walkway.
  2. Jul 2, 2010 at 7:48 AM
    JDMcQ
    Good luck Joe.
    What is the job?
  3. Jul 2, 2010 at 7:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Good luck Joe!
    :pray:
  4. Jul 2, 2010 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ok....Its strength is going to be determined by its boarder, and base. What I have done out here, in an unstable area, and a brick paver type walk way, is use a sand base, se tthe pavers, then, get about 2 gallons of white glue. Its prettty cheap at a construction supply. After the pavers are set, mix some sand with some water, and glue mix. About 1 cup of glue, per 5 gals of water. Make a runny paste consistancy. The glue will act as a binder for the sand, but, being as it rermains pliable to a degree, it wont allow cracks to form in the paver joints. You dump the sand/water/glue on top of the pavers, smear it around with a trowel, then wash it into the cracks with a hose.
  5. Jul 2, 2010 at 7:54 AM
    JDMcQ
    Won't that dissolve over time in the rain? Not that affects Aridzona much.
  6. Jul 2, 2010 at 7:54 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Controller Operator at Citrosuco in the port of wilmington. They said I was a perfect match for what they are looking for.
  7. Jul 2, 2010 at 7:55 AM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    They told me it would be 2-3 weeks before they make a decision for the second interview.
  8. Jul 2, 2010 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. My friend who we did this for, has sprinklers set up along the edge of this walkway, and they water daily. Its been 12 years, and its still crack free. The only issues are, its a little uneven, due to ground settling. We didnt have lab samples taken of the section in which we did this, so, it has settled a bit. There is about a 3/4"+/- elevation change in 15 feet. The other 40 feet is fine.
  9. Jul 2, 2010 at 8:01 AM
    JDMcQ
    Awesome. I hope it works out. That company made me think of:
  10. Jul 2, 2010 at 8:02 AM
    JDMcQ
    Very interesting.
  11. Jul 2, 2010 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Operates controlers? :confused:
  12. Jul 2, 2010 at 8:10 AM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    I will be loading trucks thru a blending system...aka push this button to make this go there.
    With my backround they said they may cross train me to do maintenance on pumps and systems. This is what I would rather do, but hell I just want a real job.
  13. Jul 2, 2010 at 8:11 AM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    :laugh:
  14. Jul 2, 2010 at 8:17 AM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
  15. Jul 2, 2010 at 8:29 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I was going to do a paver patio, but decided to go with the quickrete walkmaker - using just bagged cement and you don't need to put down the base....
    Thanks for the info on the sand / glue combo... want to seal between the pieces of "pavers".
    My ground is sand and the only movement is from where the water has been washing it out :eek:
  16. Jul 2, 2010 at 8:30 AM
    ImpulseRed008
    Susan
    SC
    I will be leveling the ground and compacting it before hand
  17. Jul 2, 2010 at 8:34 AM
    ImpulseRed008
    Susan
    SC
    Best of Luck Joe.
  18. Jul 2, 2010 at 9:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How thick are you going to make it? AND>..What kinda things are going to be on it?
  19. Jul 2, 2010 at 9:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2! Congrates! :)
  20. Jul 2, 2010 at 9:12 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
