JDMCQ's Garage
Discussion in 'Off-Topic Discussion' started by JDMcQ, Jul 26, 2009.
  1. Oct 14, 2009 at 11:38 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    :laugh:
  2. Oct 14, 2009 at 11:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    WHY THE FUCK is Burg useing a hammer???
  3. Oct 14, 2009 at 11:39 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    from what i can see is theres 4 bolts that attach it to the suspension compenents and theres a couple bolts where the brake line comes in around the bleeder valve... but theres two sets of brakes lines coming in to which is weird but ive never messed with drums b4
  4. Oct 14, 2009 at 11:39 AM
    JDMcQ
    JDMcQ [OP] Well-Known Member
    The Mushroom Capital of the World
    You need to un-adjust the brakes. And quit hitting it with a metal hammer, you are going to crack the drum.
    Remove the oblong rubber plug on the backing plate. Get two flathead screwdrivers. One pushes the adjuster ratchet out of the way, the other spins the adjustment wheel. Loosen the brakes and it should come off.
  5. Oct 14, 2009 at 11:40 AM
    Burgman
    Stephen
    Ric VA
    im trying to take change the brakes on a 2000 celica and the passenger drum will not budge, i think b/c the shoes are out
  6. Oct 14, 2009 at 11:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Burg...Are you trying to get the drum off?
  7. Oct 14, 2009 at 11:41 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    He's trying to get the drum off his old lady's car so he can replace the brakes...
  8. Oct 14, 2009 at 11:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take a 10mm bolt....stick it into the threaded hole in the drum, and tighten it. It will pull the drum right off.
  9. Oct 14, 2009 at 11:41 AM
    Burgman
    Stephen
    Ric VA
    going into the rain will be back with results
  10. Oct 14, 2009 at 11:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take a bolt from the horn mount.
  11. Oct 14, 2009 at 11:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    :popcorn:
    This is turning into a severe cluster fuck.
  12. Oct 14, 2009 at 11:48 AM
    JimBeam
    JB
    2015 Tundra
    i think the best option is to go without rear brakes
  13. Oct 14, 2009 at 11:49 AM
    JDMcQ
    The rear brakes don't really do much anyway.
  14. Oct 14, 2009 at 11:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are WAY over ratted
  15. Oct 14, 2009 at 11:53 AM
    Burgman
    Stephen
    Ric VA
    well chris's way worked
  16. Oct 14, 2009 at 11:53 AM
    Burgman
    Stephen
    Ric VA
    yea seem to do alot when the never stop stopping
  17. Oct 14, 2009 at 11:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Of course it did. :cool:
  18. Oct 14, 2009 at 11:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    "Would you like some coffe with your slice of humble pie?"
    :p
  19. Oct 14, 2009 at 11:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes please.....
  20. Oct 14, 2009 at 11:56 AM
    JDMcQ
    English?
