JDMCQ's Garage
Discussion in 'Off-Topic Discussion' started by JDMcQ, Jul 26, 2009.
  1. Dec 12, 2011 at 8:01 AM
    krap22
    krap22 Well-Known Member
    uh oh, Lisa's wooting again.
  2. Dec 12, 2011 at 8:03 AM
    krap22
    http://lmgtfy.com/?q=excel+random+number+generator
    first link
  3. Dec 12, 2011 at 8:06 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Coffee kicked in! :)
    Mornin' Adam...everyone else.
  4. Dec 12, 2011 at 8:24 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Nope that aint it, i need to use the random number generator that is in the data analysis toolpak. My problem is that i cant figure out to make it do just integers. It does decimals which doesnt work for lottery numbers that im trying to generate
  5. Dec 12, 2011 at 8:27 AM
    krap22
    can you take the decimals and multiply by 100 (or what ever it is to get a whole number)
  6. Dec 12, 2011 at 8:39 AM
    krap22
    I just played with it in excel. Can you use Excel to round off the numbers once you generate them?
  7. Dec 12, 2011 at 8:41 AM
    Burgman
    Stephen
    Ric VA
    there is a way to generate whole numbers i just dont know how, ive seen the professor do it before. dont remember tho
  8. Dec 12, 2011 at 8:43 AM
    krap22
    i didn't see how to do that. I was able to generate the numbers, round it off, then i copied just the values to another column.
  9. Dec 12, 2011 at 8:48 AM
    Burgman
    Stephen
    Ric VA
    i need 56 variables to have a total of 3370 results which is way too many values to edit, theres a way of doing it. SO the results should be 1,5,56,34,40, etc 3370 times
  10. Dec 12, 2011 at 8:49 AM
    krap22
    that is what i got, but i have to do minor tweaking after it generated the numbers.
  11. Dec 12, 2011 at 8:57 AM
    Burgman
    Stephen
    Ric VA
    so how is yours set up
  12. Dec 12, 2011 at 9:01 AM
    krap22
    i did the random number generator as part of the data analysis toolpak.
    number of variables: 0
    Number of random numbers: 3370
    Uniform number selection
    parameters between 1 and 56
    output to a new work book.
    the first column will have 3370 numbers betwen 1 and 56. in b2 i put =ROUND(A1,0) which will round to the nearest whole number. I then copied it to the rest of that column. then i copied that column and did a special past to the next column and selected values to have only the values listed not the formula.
  13. Dec 12, 2011 at 9:05 AM
    MTgirl
    Weesa
    :annoyed: I hate drawing curved walls!!!
  14. Dec 12, 2011 at 9:07 AM
    krap22
    what's so bad about curved walls? your just drawing them.
  15. Dec 12, 2011 at 9:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Why didn't you just format the column?
  16. Dec 12, 2011 at 9:08 AM
    krap22
    formatting the column doesn't change the underlying value. i tried that first. If you are going to use the numbers for some other calculations, then it would give you skewed results.
  17. Dec 12, 2011 at 9:19 AM
    Burgman
    Stephen
    Ric VA
    that worked, now i just need to count the times the times each variable occurs... any help with that formula. Seems like is should be just a count function but im having no luck. So im looking for a forumla that =(1,A1:A3370) and gives me a total. i would do that 56 times
  18. Dec 12, 2011 at 9:20 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    =RAND() generates random values in Excel... Is that what you were after?
  19. Dec 12, 2011 at 9:26 AM
    MTgirl
    Weesa
    it takes 10x's longer to draw them :goingcrazy:
  20. Dec 12, 2011 at 9:26 AM
    Burgman
    Stephen
    Ric VA
    got the countif funciton working, thanks everyone ill be back probably
