JD's '02 Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by Cr250jumper, Dec 3, 2010.
  1. Mar 7, 2013 at 11:00 AM
    #581
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I'd typically say sliders hitting the body but you don't have any so I'm slightly stumped. Body Mounts are definitely a possibility.
    Can you figure out which direction the noise is coming from when driving?
  2. Mar 7, 2013 at 11:04 AM
    #582
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Max my sliders do that, is that bad? I can lift the truck from them though.
    Sorry for the thread jack JD
  3. Mar 7, 2013 at 11:07 AM
    #583
    Cr250jumper
    Cr250jumper [OP] Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Its coming from the front somewhere. I can hit bumps, turn, and brake with no sounds. But as soon as I hit something off camber that makes it flex it sounds like a metal on metal scrape with a pop. Similar to a shitty car with blown out LCA bushings when you go in reverse and hit the brakes lol
  4. Mar 7, 2013 at 11:08 AM
    #584
    theduck911
    Max
    Locked and Geared!
    Not really, it's just them hitting the pinch weld underneath the cab, its more annoying then anything. You can just notch both sides around the leg then hammer back the piece with a chisel or whatever you can get in there so its no longer close to it. It'll most likely be one of the front legs on the sliders.
  5. Mar 7, 2013 at 11:09 AM
    #585
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    I used to get a pop like that as well. It was the coil spring moving on the retainers. I added a little more preload and it seemed to go away.
  6. Mar 7, 2013 at 11:11 AM
    #586
    theduck911
    Max
    Locked and Geared!
    Oh okay, I get what you're getting at now, that analogy actually makes sense to me :p
    Still confused if it's none of the usual, Bushings (A-Arms, Steering etc) all good and tight?
  7. Mar 7, 2013 at 11:37 AM
    #587
    Cr250jumper
    The moon
    50 shades of tan©
    Could be an upper inner arm bushing, my kit is about 2 years old and approx 40k miles. Steering is tight, bushings were replaced last year. Replaced lower ball joints last year too but its similar to that noise so I am going to check those again. Its just odd because it doesnt pop if I hit something hard enough to make the suspension move, it only does it if I am going really slow and it flexes the frame
  8. Mar 7, 2013 at 11:48 AM
    #588
    Cr250jumper
    The moon
    50 shades of tan©
    Oh I can also feel the "pop" in the floor board but not the steering wheel
  9. Mar 7, 2013 at 11:50 AM
    #589
    03aztaco
    03aztaco Well-Known Member
    adam
    lake havasu,mesa
    03 prerunner
    tc lt kit, king shocks, deavers, tc hangers,tc 12" shackels, king double bypasses, cab caged, beefed taco carrier bearing drop bracket, soild motor mounts,some more to lazy haha
    Sounds like ur cabs moving mine did the samething
  10. Mar 7, 2013 at 12:00 PM
    #590
    Cr250jumper
    The moon
    50 shades of tan©
    Thats what I am starting to think, when I removed all the interior body panels everything got a lot louder so maybe I am just noticing it. I found many places with large splits in the cab. Looks like I may just need to hurry and cage it and get rid of all this flexing nonsense :D
  11. Mar 7, 2013 at 1:41 PM
    #591
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    Ha u wish its going to get louder lol atleast mone is, and ya when i started caging mine i noticed my whole back end of my cab was split
  12. Mar 7, 2013 at 6:02 PM
    #592
    Cr250jumper
    The moon
    50 shades of tan©
    Well I checked pretty much every bolt I can see and found a few a little loose here and there and took it for a drive and it still pops. Is a carrier bearing possible? It's been on its last legs and I'm sure the in bolted tranny didn't help. I've seem to develop a bit of a shake around 75mph on the hwy but that could be my tires. But maybe I'm flexing the rear end and popping the carrier bearing and hearing it pop through the cab
  13. Mar 7, 2013 at 6:12 PM
    #593
    05TacoRunner
    Peoria, Az
    Race trucks make race truck noises?
  14. Mar 7, 2013 at 6:40 PM
    #594
    theduck911
    Max
    Locked and Geared!
    Yeah, but after 2 years you'd be used to the race truck noises and notice things that are actually a problem :notsure:
  15. Mar 7, 2013 at 6:55 PM
    #595
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    Hmmmm mabey ive also lost a couple bolts off my lower balljoint and had the tierod hit the dust protector before other then that motor mounts mabey
    Edit you already checked motor mounts
  16. Mar 7, 2013 at 7:06 PM
    #596
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    Ok now i just crawled under my truck and the only thing i see by the floor board is the steering shaft:confused: mabey that
  17. Mar 7, 2013 at 7:14 PM
    #597
    Cr250jumper
    The moon
    50 shades of tan©
    Ok just found one more set of fairly loose bolts. The bolts that hold the upper shock mount into the coil bucket, driver side had 2 loose, and all 3 passenger side was fairly loose. I'll drive it tomorrow and see
  18. Mar 7, 2013 at 8:10 PM
    #598
    05TacoRunner
    Peoria, Az
    Agreed just giving JD a hard time.
  19. Mar 7, 2013 at 10:17 PM
    #599
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    Hmmmm i think you just solved your problem
  20. Mar 8, 2013 at 7:42 AM
    #600
    Cr250jumper
    The moon
    50 shades of tan©
    Lol no worries, it didn't make any noises this morning but its raining pretty hard so everything is wet. We'll see
