JeepAndrew's AZ Trail Runs/Campouts
Discussion in 'Arizona' started by JeepAndrew, Feb 26, 2013.
  1. Mar 2, 2014 at 3:24 PM
    #6261
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I am going ARB but I have to piece it all together as I cant afford it outright.
  2. Mar 2, 2014 at 3:24 PM
    #6262
    mh.meier
    The Doctor
    Commiefornia
    I can appreciate how I was left out.....
  3. Mar 2, 2014 at 3:27 PM
    #6263
    AzCrawlin
    AzCrawlin Fuck that rock.
    Derrick
    Tucson AZ
    2010 pyrite-micha DCSB 4x4 sport
    Got the horrible wheel squeak taken care of, just to be greeted by another mildly annoying squeak from the other side!!!!
    #jeeproblems lol
  4. Mar 2, 2014 at 3:28 PM
    #6264
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Well we had to boot you off the list to put Jake on the list
  5. Mar 2, 2014 at 3:35 PM
    #6265
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    So we tightened all suspension but couldnt get clips to work for the extended break lines so we just put the stock ones back on. Won't have time to put them on so I will need to be careful. But should be fine. There is still a good amount of travel
  6. Mar 2, 2014 at 3:41 PM
    #6266
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    Don't worry buddy. I added ur name to the list on the ck run thread:thumbsup:
  7. Mar 2, 2014 at 3:42 PM
    #6267
    mbmack1
    matt
    az
    SAVAGE silver '06
    Which rears shocks are u running?
  8. Mar 2, 2014 at 3:43 PM
    #6268
    Infra
    Az
    Well now you've been taken off the list
  9. Mar 2, 2014 at 3:44 PM
    #6269
    snowtank
    Andrew
    Arizona
    Billies
  10. Mar 2, 2014 at 3:46 PM
    #6270
    mbmack1
    matt
    az
    SAVAGE silver '06
    :brianr:
  11. Mar 2, 2014 at 3:49 PM
    #6271
    mbmack1
    matt
    az
    SAVAGE silver '06
    The ones that come with the toytec ultimate designed for a 2" lift or the longer ones for the rcd 4" lift?
  12. Mar 2, 2014 at 3:52 PM
    #6272
    snowtank
    Andrew
    Arizona
    I believe the 2" . Jason would know better than myself tho
  13. Mar 2, 2014 at 3:55 PM
    #6273
    mbmack1
    matt
    az
    SAVAGE silver '06
    Then ur good with stock rear break lines. The shock will run out of droop before ur break line runs out of slack. At least thats how my truck was. Jack up the right rear tire until the left tire loses contact with the ground and see if the lines still have slack on them. A ramp would work better than a jack.
  14. Mar 2, 2014 at 3:57 PM
    #6274
    snowtank
    Andrew
    Arizona
    We jacked up just the body and let the axle just hang and thrre was still slack . It was close but still had enough for another 2 " or so
  15. Mar 2, 2014 at 4:00 PM
    #6275
    mh.meier
    The Doctor
    Commiefornia
    Youll be fine Andrew, fuck off Jason for leaving me out, I have never been there so I'll just go on my own and let all those who have already been go again, thank you Matt for your kindness, we are twinsies after all.
  16. Mar 2, 2014 at 4:01 PM
    #6276
    mh.meier
    The Doctor
    Commiefornia
    Also operation Jello Shot has commenced. Cheesecake pudding shots, black cherry and strawberry Jello Shots!
  17. Mar 2, 2014 at 4:01 PM
    #6277
    Infra
    Az
    They are the extended length billies designed for the RCD lift
  18. Mar 2, 2014 at 4:01 PM
    #6278
    mbmack1
    matt
    az
    SAVAGE silver '06
    Then ur $$$ my friend. I ran my truck like that for 2 years with no problems. I only ran into a problem when I put on the longer shocks.
  19. Mar 2, 2014 at 4:03 PM
    #6279
    mbmack1
    matt
    az
    SAVAGE silver '06
    Oh.well if he's got slack then he'll be alright.
  20. Mar 2, 2014 at 4:04 PM
    #6280
    snowtank
    Andrew
    Arizona
    I just need to figure out a bracket that will work and problem solved no big deal. And since I know what the problem is it will be easy to figure out a solution
