JeepAndrew's AZ Trail Runs/Campouts
Discussion in 'Arizona' started by JeepAndrew, Feb 26, 2013.
  1. Mar 5, 2014 at 3:01 PM
    #6581
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Ok so the Firestone guy said on 2 different occasions that one of my inners had some slight play. I have had the truck jacked up quite a few times at full droop and do the wiggle test and I don't feel any play. I can turn all around side to side just fine with no noise or pop, but at certain angles and just since we did axles have I felt this new occasional pop when backing out at full turn.
    As long as some of you are wheeling with bad tie rod ends, I won't feel alone :/ Is anyone bringing spares?
  2. Mar 5, 2014 at 3:03 PM
    #6582
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I can bring my old ones along but I wouldn't trust them much lol.
    Keep in mind, I have like 3" of play side to side by hand. The truck will be putting way more force side to side than a human can.
  3. Mar 5, 2014 at 3:06 PM
    #6583
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Damn I don't have any play like that. Yikes!
    I checked Rock Auto and the Moog inners are only like $20 each. That's cheap. I expect this will be my next and last front end project for a while. I don't have time to order them in before Rug Road so I'll just roll the dice. Bring those old tie rod ends with just in case... I'd rather have a bad one than a totally broken one.
  4. Mar 5, 2014 at 3:07 PM
    #6584
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    yeah i bet its your tie rods adam.
    sounds good to me.
    both of my tires have some play side to side. passenger side is the tie rod, and the driver side is UCA bushings for me.
    i have 1 "bad" tie rod i guess. but it doesnt make noises. but it has a few inches of play in it.
    mise well bring your old ones, never know when they will come in handy to get a rig off the trail. i try and keep my old ball joints just incase.
  5. Mar 5, 2014 at 3:09 PM
    #6585
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Shits pippin off In this thread :D
    Get it?! That was punny!
  6. Mar 5, 2014 at 3:10 PM
    #6586
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    It will eliminate the pucker factor by a couple percent if I know there is a spare in the group.
    With the way it pops, it makes me wonder if those new CV's are just settling in or something. It only happens very rarely and it's hard to re-create. Usually only happens in reverse, too, which will be a minimum on this trail hopefully. When I wheeled at New River, I only had it pop once on a steep downhill at an odd angle but after that it was fine on other odd angles. Tough to pinpoint.
  7. Mar 5, 2014 at 3:14 PM
    #6587
    4runnercaged
    cody
    arizona
    LOL
    weird.
    i really doubt your cvs will be popping. and if it is, you got a problem with that cv.
  8. Mar 5, 2014 at 3:15 PM
    #6588
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Looks like I'm out. Got a very loose cv boot.
  9. Mar 5, 2014 at 3:15 PM
    #6589
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    I see what you did there.
  10. Mar 5, 2014 at 3:16 PM
    #6590
    Brian007Taco
    That's not good. Out as in you are not coming at all?
  11. Mar 5, 2014 at 3:19 PM
    #6591
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I sure hope not. They're brand new and went on with no issues. Everything torqued to spec and there were no problems with the install.
  12. Mar 5, 2014 at 3:20 PM
    #6592
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I call BS. No way that would stop you.
  13. Mar 5, 2014 at 3:21 PM
    #6593
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Psh go anyway. My pass side is still loose. Be aight.
  14. Mar 5, 2014 at 3:21 PM
    #6594
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Er i meant infra lol. Phone fail
  15. Mar 5, 2014 at 3:22 PM
    #6595
    4runnercaged
    cody
    arizona
    LOL
    loose? bailing wire, zip ties, plastic coat hanger and a lighter, something can fix it lol.
    i really doubt it. if it was your cvs popping i think it would already be done for, and you would definitley know if it was a cv.
    i think youll be fine.
    yes i agree.
    and if it is stopping you, i can bring a new boot to tucson thursday night and we can throw that bitch on :D
  16. Mar 5, 2014 at 3:24 PM
    #6596
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    His truck is evil. We couldn't get his fucking spline to come off... The easiest part lol
  17. Mar 5, 2014 at 3:25 PM
    #6597
    4runnercaged
    cody
    arizona
    LOL
    inner or outer?
  18. Mar 5, 2014 at 3:27 PM
    #6598
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Outter. Was sone kind of fluke thing. The dealer said they had no issue with it. I've pulled mine off several times without issue too
  19. Mar 5, 2014 at 3:29 PM
    #6599
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    You would have to be dying for me to not let you come. And even then im still 97% positive I would be taking you then too.
  20. Mar 5, 2014 at 3:30 PM
    #6600
    4runnercaged
    cody
    arizona
    LOL
    the outers are almost always a bitch, for me at least.
    you can pull the inner just by taking off the c clip and put the boot for the outer on that way? thats what i do so i dont need to take off the outer joint.
