JeepAndrew's AZ Trail Runs/Campouts
Discussion in 'Arizona' started by JeepAndrew, Feb 26, 2013.
  1. Sep 6, 2016 at 11:33 AM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    Sliders worked beautifully on Sunday doing Turkey Creek near Crown King. They saved my cab both times. Thanks @JeepAndrew !
  2. Sep 6, 2016 at 11:38 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah they did.. no idea how you got high centered. lol
    but.. I also need to give some praise on my Jeepers Sliders. FINALLY was able to use them.. have been trying but the truck always seems to clear. this time they were used! all the way down too.
    Thanks Andrew! @JeepAndrew
  3. Sep 6, 2016 at 11:51 AM
    Brian007Taco
    XPOTRPR likes this.
  4. Sep 6, 2016 at 11:58 AM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    I realized that afterwards. How much lift did the deavers provide for you?
    snowboard704[QUOTED] likes this.
  5. Sep 6, 2016 at 11:58 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  6. Sep 6, 2016 at 12:04 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Between 2-3 inches roughly
    a.smo[QUOTED] likes this.
  7. Sep 6, 2016 at 12:14 PM
    a.smo
    Aaron
    PHX, Az
    Hmm. How far back did you put the top shock mounts? Could you get me some pics whenever you get a chance? Thanks!
  8. Sep 6, 2016 at 12:15 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea I can grab you some closer pics in allitle:thumbsup:
  9. Sep 6, 2016 at 12:16 PM
    a.smo
    Aaron
    PHX, Az
    I appreciate it dude. How long did it take you?
  10. Sep 6, 2016 at 12:18 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Well we first mounted the upper crossmember not high enough so my uptravel was screwed up.. So we had to take everything out and cut it an re weld it so allitle over a full day plus Deaver install/ cycle / bumps
  11. Sep 6, 2016 at 12:20 PM
    a.smo
    Aaron
    PHX, Az
    Perfect! I'm planning two days for this so I can also weld on frame plates and make sure I have enough time for cycling and welding bumps on.
  12. Sep 6, 2016 at 12:30 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    The other way we communicate is via smoke signals. Once you see a mushroom cloud of smoke (like from doors opening) that means its time to go....... Eat
    Also, what happened to your tailgate Brian?
    05tacomabro, Brian007Taco and a.smo like this.
  13. Sep 6, 2016 at 12:35 PM
    Brian007Taco
    I was wondering when and who was going to ask. I had the tailgate down at night and backing up. Nicely tapped a tree with the tailgate down. While camping I might add.
  14. Sep 6, 2016 at 12:38 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Just make sure you get that crossmember as close to the bed as possible. Going to have to take the bed off too but it's easy
  15. Sep 6, 2016 at 12:41 PM
    a.smo
    Aaron
    PHX, Az
    I was thinking of getting some measurements before I take the bed off. Did you remove the rear crossmember?
  16. Sep 6, 2016 at 12:43 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea Definatly measure before, think it was about 2 inches above frame rail until you hit the bed... no I kept the rear crossmember but with 12s you may have to take it out... depends on how much lift the leafs give you also
  17. Sep 6, 2016 at 12:52 PM
    a.smo
    Aaron
    PHX, Az
    Awesome. I appreciate the help! I've planned on removing the crossmember. Figured it would give more a lot more space.
  18. Sep 6, 2016 at 12:55 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Tapped a tree?
    Homie, you rammed that shit like it was begging for it.
  19. Sep 6, 2016 at 1:13 PM
    RPS1030
    RPS1030 Well-Known Member
    He's getting his payback.
  20. Sep 6, 2016 at 1:20 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    I still think the tree won that one
