JeepCable Big 7
Discussion in 'Audio & Video' started by stay_tuned, Sep 1, 2022.
  1. Sep 1, 2022 at 6:44 PM
    stay_tuned
    stay_tuned [OP] Limitations live only in our minds
    Bryan
    DMV
    2021 Tacoma OffRoad DCSB 6SPD BRM
  2. Sep 2, 2022 at 5:42 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Honestly not a bad price for premade cables. Do the 1/0 and not the 2.
    Follow up question: how big is your aftermarket system? At a certain point, you will max out the alternator and will still get diMming and eventually kill your battery.
    soundman98 likes this.
  3. Sep 2, 2022 at 6:11 AM
    stay_tuned
    Bryan
    DMV
    Currently ive got an RE Audio CTX 4200.1 with a sundown SD-4 10 D2.
    Im not sure what that puts me down as far as power i doubt its that much with just the one sub but when it comes to audio I'm still learning. The amp says RMS is 1500W at 1Ohm and the sub max output is 600W but idk how much its actually putting to the sub in reality
  4. Sep 2, 2022 at 7:27 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    If you’ve set your gains on the amp correctly to only send 600w rms to the sub, you shouldn’t be having too many dimming problems in the first place. With that amp, you may be at risk of blowing your sub soon so make sure your gains are set right for that lower power subwoofer
  5. Jun 14, 2023 at 6:20 PM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    OP, what did you end up doing? Jeepcables product or ??
