Jerking issue
Discussion in 'New Members' started by Pureelement, Mar 15, 2018.
  1. Mar 15, 2018 at 11:11 AM
    Pureelement
    Pureelement [OP] New Member
    Jamie
    2014 tacoma
    My 2014 Tacoma I just bought it In sept. It is jerking right around 1500 to 2000 rpms. It doesn’t do it if I’m accelerating at a good rate but it jerks if I stay around those rpms??? Spark plug issue?? Transmission?? I just need to know where to start to get it looked at
  2. Mar 15, 2018 at 11:15 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yikes, sounds like Jimmys cutting truck. I would guess mass airflow sensor or possible throttle position sensor. Any check engine light or codes?
    wilcam47 likes this.
  3. Mar 15, 2018 at 11:19 AM
    Pureelement
    Jamie
    2014 tacoma
    Nope no lights are on at all
  4. Mar 15, 2018 at 5:42 PM
    T4RH33L
    T4RH33L Helping to find Jimmy since 2017
    Al
    Raleigh, NC
    2013 MGM DCSB TRD OR
    5100s with Eibach coils and zombie Dakars.
    :rofl::rofl::rofl:
    Poor Jimmy. He just couldn't cut it.
  5. Mar 15, 2018 at 5:45 PM
    JW87
    JW87 Well-Known Member
    JW
    Richmond,VA
    2015 TRD Sport 4x4 DCLB
    American Racing black bajas with Cooper RTXs 265/70/17. Black Depo tail lights. LED interior, license plate and reverse lights.Debadged. OME 885 coils and Dakar leaf packs. OME Nitros front and back.
    Maybe needs some lube...:bananadance:
    brandon78lusch likes this.
  6. Mar 15, 2018 at 6:42 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! Is the issue only at that rpm range?
  7. Mar 15, 2018 at 6:44 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to TW! Transmission low on fluid?:notsure:
  8. Mar 15, 2018 at 8:31 PM
    Pureelement
    Jamie
    2014 tacoma
    Yes that is the only rpm’s it jerks at
  9. Mar 27, 2018 at 4:04 PM
    steveyosh
    steveyosh New Member
    2013 Grey Dbl Cab 4WD
    Sounds exactly like the problem my 2013, 108k 4wd had a couple months back. If I sped up pretty quick, it wouldn't do it. I had that problem for several weeks and then it went away. Took it to a mechanic but he couldn't recreate the problem so it was never solved.
    So yes, the jerking problem went away but now its super sluggish. I'm not sure if the problems are related but my guess would be that they are.
    Here's a list of things I've done to try and solve the problem:
    Air filter change
    MAF sensor clean
    Spark plugs checked
    AT fluid flush
    Differential flush
    Read another post somewhere that mentioned TPS (Throttle Position Sensor) and Shift Control Solenoid as a potential culprit. But I haven't gotten to that yet.
  10. Oct 27, 2021 at 3:00 PM
    Dumneezooo
    Dumneezooo Well-Known Member
    2014 DCLB MGM TRD Sport
    Any update to this? Having same issue
