Jerking problem 99 Toyota Tacoma 4x4 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by Finaddict, Jul 27, 2016.
  1. Jul 27, 2016 at 5:09 PM
    Finaddict
    Finaddict [OP] New Member
    I am having trouble fixing a bad jerking problem with my son's 99 Toyota Tacoma 4x4 3.4L truck. I have changed the plugs, plug wires, ignition coils, fuel filter, clutch master cylinder, slave cylinder and PVC. The clutch was changed 3 years ago. Not sure what to look at next other than the throttle body cleaning. I took it to the dealer and they could not find any codes or had any idea what was causing the jerking problem. Any idea on what to look for next?
    Thanks
  2. Jul 27, 2016 at 7:55 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    more info
  3. Jul 27, 2016 at 7:56 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    need more info in regards to when its jerking. what creates the jerking. is it recreatable. etc
  4. Jul 27, 2016 at 7:57 PM
    Soccerties
    Soccerties Active Member
    Denver, CO
    2012 DC Off-Road w Habitat
    My 97 had a jerk/stuttering issue. If what you're describing is the same thing the fix was the throttle position sensor.
  5. Jul 30, 2016 at 7:13 AM
    Finaddict
    The jerking starts at all speeds from 1st to 5th gear. It appears to be a fuel related issue as the truck feels sluggish with poor fuel economy. I cleaned the Idle Control Valve and throttle body yesterday which seemed to help. I will replace the throttle position sensor and see if that helps as well.
