Truck Jerks after coil pack change ~ between 40-50 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jayunder1989, Sep 26, 2016.
  1. Sep 26, 2016 at 5:30 AM
    Jayunder1989
    Jayunder1989 [OP] New Member
    Got a 2008 tacoma. Changed the coil packs the other night and on my way to work the next day it started jerking and when I pulled off the road it shut off. Had to change spark plugs to get it to start. The jerking stopped as well for a few miles. Then came back. Mainly happens between 40 and 50 when it's under 2000 rpms. But will do it at other speeds just not as bad or as often. Also will idle funny when sitting still and in drive.
  2. Sep 26, 2016 at 5:35 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Prolly unrelated, but did u mess with the maf sensor?
    What kind of air filter are you running?
    What brought the original coil pack replacing?
  3. Sep 26, 2016 at 8:00 AM
    Pigpen
    Dan
    Northwest Montana
    I'm guessing one of the coils isn't getting juice
    scottalot likes this.
  4. Sep 26, 2016 at 1:08 PM
    Jayunder1989
    Is there a way to find out which one is not firing?
  5. Sep 26, 2016 at 1:09 PM
    Jayunder1989
    Did not mess with maf sensor unless I bumped it changing them.
    Changed them just because truck is at 135000 and they have never been changed, that I know of
  6. Sep 26, 2016 at 1:11 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    any check engine light codes?
  7. Sep 26, 2016 at 1:14 PM
    Jayunder1989
    The light came on but went off after changing spark plugs. And advance/auto zone said they cant scan it if the light isn't on...
  8. Sep 26, 2016 at 1:18 PM
    Scrubber3
    Scrubber3 Not really here
    2016 T4R XP 4X4 MS
    What brand plugs? If it's Bosch, consider that your problem. If they aren't NGK or/ and Denso, I'd put NGK/Denso in it then recheck. Copper core- gapped to spec
    tomwil and wilcam47 like this.
  9. Sep 26, 2016 at 1:19 PM
    wilcam47
    Will
    Bourbon state
    might just check to see if the wires are seated properly...
  10. Sep 26, 2016 at 2:28 PM
    Pigpen
    Dan
    Northwest Montana
    This would be the first step. It sounds like you're getting intermittent or weak spark to one cylinder. One of the coils might not have been tightened enough or didn't seat properly. That kind of unlikely though, since you changed the coils the did the plugs later. I'd guess your trouble isn't at the plug end of the coil that's causing trouble.
  11. Sep 26, 2016 at 3:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The process to check the coil packs is simple, for which one is being problematic. While the truck is idling improperly, then unplug then reconnect each call pack, one at a time, and see if it makes the truck's engine idle changes. The plug which does not cause the engine to stumble worse is the one suspect coil pack/plug
  12. Sep 26, 2016 at 4:06 PM
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    His case is only while driving it from what he said. This option may not work because the CP is getting proper voltage while at the idle speed but not at certain RPMs above that. your options are to recheck that each CP is on the plug proper, or that each CP is plugged in securely to the wire harness then go drive it or each time after.
    But im guessing that you have a bad CP. I Just dealt with this on my f350 and it was a bad CP same symptoms and all. The CP works under acceleration just fine but when you try to cruise it bucks intermittently. mine didn't even throw a code because the misfire wouldnt happen for long enough, i guess, so i had to change them individually to find the bad one. annoying yes. pretty easy though
    I have heard of brand new CP being bad out of the box but not terribly often if you buy decent quality
    Jayunder1989[OP] likes this.
  13. Sep 26, 2016 at 5:17 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Yep, Bosch seems to have an incompatibility problem.
    Maybe put the original coil packs back on, and see if the problem still exists?
  14. Sep 26, 2016 at 5:55 PM
    Pigpen
    Dan
    Northwest Montana
    Totally disappointed with the title change. It was way more fun before.
  15. Sep 26, 2016 at 5:57 PM
    Bishop84
    Bishop84 Well-Known Member
    I've had bad coil packs out of the box, or the wrong one used. Sometimes the "oem" denso coils don't sit right as they are one part # off.
  16. Sep 26, 2016 at 9:38 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Swap the original coil packs back in, and confirm the issue is resolved. They are not a maintenace item, and if you bought cheap aftermarket replacements, most likely one or more is defective.
    Jayunder1989[OP] and Scrubber3 like this.
  17. Sep 26, 2016 at 9:51 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    There is no reason to replace the OE coil packs unless one has failed, and even then it's on an as needed basis.
