Jerks into drive from park?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtyler1, Feb 15, 2011.
  1. Feb 15, 2011 at 3:38 PM
    jtyler1
    jtyler1 [OP] Active Member
    07 PreRunner DCLB
    Anyone else had a jerking issue when shifting from park to drive with a/t trans.?
  2. Feb 15, 2011 at 3:54 PM
    jtyler1
    07 PreRunner DCLB
    nope. no parking brake involved. just regular brake. hmm?
  3. Feb 15, 2011 at 3:54 PM
    jtyler1
    07 PreRunner DCLB
    And im sure a little jerk is normal but this seems a little aggressive
  4. Feb 15, 2011 at 4:00 PM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    yeah mine does this also. it seems to do it worse when its cold.
  5. Feb 15, 2011 at 4:02 PM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    Only when I'm on a hill, it's loud.
  6. Feb 15, 2011 at 4:02 PM
    jtyler1
    07 PreRunner DCLB
    oh yea? well its pretty cold here now so maybe i will wait it out. think its worth worrying about?
  7. Feb 15, 2011 at 4:13 PM
    Pannell_Trd
    Tyler
    Georgia
    Mine does it on flat ground. when the truck is warm it never does it. i thought about taking it to the dealer and see what they say about it.
  8. Feb 15, 2011 at 4:16 PM
    ChuckD05
    ChuckD05 Active Member
    WV
    2011 DC TRD Offroad V6
    If the Truck has just been started, it will be idleing high to warm itself up faster.
    Normally 1300-1500rpm.
    When you put it into D for Drive, it forces the rpm's down into the 1000rpm range which could cause a jerk or lunge.
  9. Feb 15, 2011 at 4:19 PM
    jtyler1
    07 PreRunner DCLB
    pretty flat here on eastern shore of md. so dont use parking brake too often.
  10. Feb 15, 2011 at 4:23 PM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    Not here and I put the truck in neutral at lights...Don't care for the low RPM trans vibration at longer lights (plus from what i have read it actually saves fuel not fighting the trasnsmisson)
  11. Feb 15, 2011 at 4:30 PM
    loaderman82
    loaderman82 Well-Known Member
    Dalton
    Flippin, AR
    2008 Off-Road
    Mine does that too, but I just tell myself it is all that power ready to be unleashed!!
  12. Feb 15, 2011 at 4:31 PM
    jtyler1
    07 PreRunner DCLB
    hahah i like that
  13. Feb 15, 2011 at 4:32 PM
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    Mind over matter! :D
  14. Feb 15, 2011 at 4:50 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    my guess also
  15. Feb 15, 2011 at 6:40 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    If its in high idle it will "bump" into D.
  16. Oct 11, 2012 at 9:29 AM
    Okeetee
    Okeetee I like the Anaheim Ducks
    Kyle
    Huntington Beach, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 18x9 Pro Comp series 7032, Toyo Open Country A/T II (LT285/65R18)
    Sorry to bump an old thread but I figured I'd take this route instead of starting a new one.
    I experience this same thing every morning when I go from park -> drive. I always use my parking brake but it's only when I shift into drive that I feel a significant jerk. Hope everything is ok.
    Seems to only happen when the truck is cold (sitting overnight). Maybe I should let it idle longer? I usually let it warm up until I get buckled it and situated -- so about 20-30 seconds.
  17. Oct 11, 2012 at 9:46 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    When you shift out of park try stopping at neutral for a few seconds...then make the shift into drive. Also, when parking before going from drive to park stop at neutral, set the emergency brake, let truck seat itself by taking foot off brake pedal for a second, then shift into park. Doing it this way seems to take the load off the tranny and lessons the hard shift from park to drive on start up.
  18. Oct 11, 2012 at 9:55 AM
    Okeetee
    Kyle
    Offroad,
    I've tried letting it sit in neutral (like you mentioned) before shifting into drive but it still jerks. Pretty weird.
    And that's how I go from drive to park. :D I can thank TW for that.
  19. Oct 11, 2012 at 5:14 PM
    OffroadToy
    I've read some taco's come from the factory low on tranny fluid....might be worth checking if you haven't allready.
  20. Oct 11, 2012 at 5:47 PM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    She needs to warm up a little longer, never stab a cold motor. Do it how you normally do and watch the rpm gauge, remember the rpms you were at when it lunged, then warm it up longer then see the rpm and remember what they were at and see if she lunges?
    Same with women
