Jerky acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GibbsTacoma, Jan 24, 2021.
  1. Jan 24, 2021 at 9:46 AM
    GibbsTacoma
    GibbsTacoma [OP] Well-Known Member
    Charlotte Metro Area
    2010 Tacoma TRD Sport DCSB 2wd
    Hi friends, I have a 10 Tacoma TRD Sport 2wd and lately I've been experiencing jerking while accelerating. The jerking only occurs when I'm constantly driving within 40-60 mph. It would occur about 3 to 4 times for about a split second then everything would go back to normal. 8 months ago I had the tranny fluid changed. Since this occurs when I'm hitting the gas, I figured it was a throttle issue.thought it was the throttle body so I cleaned both throttle body housing and MAF cleaner. However it started again after a short test drive. Not sure what the issue is. Anyone experienced this issue, please advice.
  2. Jan 24, 2021 at 10:06 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you believe it to be transmission related check this thread, it's a good writeup about the 2nd gen automatic.
  3. Jan 24, 2021 at 10:15 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Could be your
    Throttle control module (at the pedal) we are fly by wire for throttle
    Throttle position sensor
    Check for codes (dash light doesn't always come on when a code is stored)
    GibbsTacoma[OP] likes this.
  4. Jan 24, 2021 at 10:22 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Another thing that could cause a jerk as you describe is a missfire.
    b_r_o and 12TRDTacoma like this.
  5. Jan 24, 2021 at 10:25 AM
    GibbsTacoma
    The truck isnt throwing any codes. I changed out all 6 plugs when I first got this truck last February.
  6. Jan 24, 2021 at 10:27 AM
    GibbsTacoma
    From the replies it seems like a torque converter shudder issue, throttle control issue, possible fuel pump or a possible misfire. The only thing is that this truck isnt throwing any codes. I heard there was a TSB for torque converter problems with these transmissions.
  7. Jan 24, 2021 at 10:29 AM
    Not a golfer
    Calgary, Alberta
    Also possible fuel pump
    I had a 92 GMC that did this and it turned out being the pump
    12TRDTacoma likes this.
  8. Jan 24, 2021 at 10:29 AM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    Mmmmmmm............deer jerky
  9. Jan 24, 2021 at 10:29 AM
    GibbsTacoma
    I'm going to run to Autozone and have them check
  10. Jan 24, 2021 at 10:30 AM
    GibbsTacoma
    I also considered this a few months ago as well
  11. Jan 24, 2021 at 10:35 AM
    Not a golfer
    Calgary, Alberta
    Do you have a mechanic you trust?
    Doesn't hurt to spend a few bucks and know for sure before spending money in hope of fixing (been there done that wish I hadn't)
  12. Jan 24, 2021 at 10:35 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    TCC shudder and ignition miss can often feel the same, usually you can differentiate them by watching the tach, if it bounces up and down when the jerk occurs it's likely TCC shudder.
  13. Jan 24, 2021 at 10:44 AM
    GibbsTacoma
    Excellent advice. There are two local mechanics that used to work at Toyota. Since it could be a factor of 3-4 issues, it's best to let a mechanic figure it out since I'll just be spending to trial and error.
  14. Jan 24, 2021 at 10:46 AM
    GibbsTacoma
    My tach remains stable with the jerky feel. Therefore it may not be this then.
  15. Jan 24, 2021 at 10:49 AM
    Not a golfer
    Calgary, Alberta
    For sure
    I sold a truck because I thought the problem was big. Saw the truck two days later for sale for three times what I sold for.
    Life lesson 1245000000000000000000000000000000 (I can be a cheap SOB and slow learner at times)
  16. Jan 24, 2021 at 10:55 AM
    GibbsTacoma
    :annoyed:
  17. Jan 24, 2021 at 11:00 AM
    Not a golfer
    Calgary, Alberta
    Yeah
    I'm still kicking myself for that one
    If you take your truck in and they find problem. Post the repair so others know if it happens to them.
  18. Jan 24, 2021 at 12:19 PM
    GibbsTacoma
    I will definitely keep this post updated with my findings
  19. Feb 6, 2021 at 6:12 PM
    GibbsTacoma
    Update,
    Today I did the 120k maintenance along with rear differential fluid. I also added Lubeguard Instant Tranny Shudder fix and Lubeguard Tranny Additive. I drove it 5 miles and noticed improvements
  20. Jun 25, 2022 at 9:30 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Hi, I'm chiming in because my 2010 with 100,000 miles started doing this. It would jerk between 40 mph and 60 mph while driving on any incline, but it happens randomly and not throwing any codes. I drained and filled my transmission fluid twice already at 90,000 miles. Just wanted to check in with you if that additive you put in has fixed your problem permanently?
