Jerky when in 4wd?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Standup, Jan 28, 2013.
  1. Jan 28, 2013 at 9:42 PM
    Standup
    Standup [OP] Active Member
    I have a 99 tacoma trd with 99k miles on it I just got a week ago. When I put it the truck in 4 high and make a sharp, slow left or right turn it almost feel like the tires are rubbing and the truck kind of lightly lurches forward? It does not do this in 2 high. What could be wrong?
  2. Jan 28, 2013 at 9:44 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    did you have the 4wd engaged on pavement? if so than the 4wd system was binding
  3. Jan 28, 2013 at 9:48 PM
    Standup
    Yes, I was on the pavement when I was turning sharply/slowly but it was snowing out so I engaged the 4wd in case the roads got slippery. And just realized I posted this in the wrong section.
  4. Jan 28, 2013 at 9:49 PM
    acdronin
    acdronin Well-Known Member
    When you are in four-wheel mode, both tires are driving at the same rate, when you turn, whatever tires are on the inside of the turn rotate slower that the ones on the outside, but they are still wanting to spin at the same speed, hence the 'jerkiness' you describe. Because of this, it's very important to the life of your drive train to only use four wheel drive on surfaces that allow the tires to break traction if they need to. If you drive like that on hard surfaces, this will cause the drive-train to do what's called 'binding', a nasty thrashing of your drive-train which can ruin it.
  5. Jan 28, 2013 at 9:50 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    its completely normal...unless it is really slippery out..I would be careful about engaging 4wd on pavement.
  6. Jan 28, 2013 at 9:52 PM
    Standup
    So pretty much only engage it on snow or ice?
  7. Jan 28, 2013 at 9:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Try not to turn too sharp in 4wd
  8. Jan 28, 2013 at 9:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    no you can engage it whenever. Just don't try and turn unless the tires can slip (like in soft dirt, ice, snow, etc.)
  9. Jan 28, 2013 at 9:57 PM
    acdronin
    Well, yeah, off-road in dirt or mud, snow and ice on roads is OK, just have to be aware of what the road conditions are suitable for four-wheel drive. If the conditions improve or start to dry, put it back in two-wheel drive. Basically use four-wheel drive on pavement only when you absolutely have to. Like Pete said, I wouldn't turn too sharply either, it's just tougher on the drive-train.
  10. Jan 28, 2013 at 10:11 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    This belongs in the 1st. Gen section since the OP has a 99 :cookiemonster:
  11. Jan 28, 2013 at 10:17 PM
    acdronin
    thank you grumpy cat:cool:
  12. Jan 28, 2013 at 10:20 PM
    MonkeyProof
    SoCal- SGV
  13. Jan 29, 2013 at 12:12 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I usually eat jerky when i'm in 4 wheel drive. but never on the pavement.
  14. Jan 29, 2013 at 12:16 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    The tight u-turns and fast tight 3 point turns are not for 4 wheel drive.
    More radius turns when engaged.
  15. Jan 29, 2013 at 12:17 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    That's what I thought the thread was about to be honest:anonymous:
  16. Jan 29, 2013 at 12:34 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    That's why you have a front & rear diffs.
    The problem is caused by the front wheels covering more ground than the rear wheels on turns.
