Jerretxx: truck collection, build thread, and BS thread
Discussion in 'Other Builds' started by jerretxx, Apr 10, 2013.
  1. Nov 26, 2013 at 7:21 AM
    #61
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
  2. Nov 26, 2013 at 4:22 PM
    #62
    jerretxx
    jerretxx [OP] Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    Well, I picked my alternator up today, an went to install it, and it was a no go. Seemed like it was taller than the original. Hopefully it was boxed wrong or something.
  3. Nov 28, 2013 at 8:00 AM
    #63
    jerretxx
    Jerret
    North Carolina
    ran into a snag with the truck. It stopped charing and the charge light is on on the dash. Also, If you disconnect the positive battery cable while its running, the truck cuts off. I replaced the alternator and it is still doing the same thing. I cant find a fuse or anything like that for the alternator. I am wondering if its the external voltage regulator. Any advice would be great!
  4. Nov 28, 2013 at 8:10 AM
    #64
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Return the alternator and get an internally regulated from a later model, they pump a little more juice too. You can search for a write-up on the wiring process. As a matter of fact, I have my 85's old alternator at home if you want it, you're welcome to have it.
  5. Nov 28, 2013 at 8:40 AM
    #65
    jerretxx
    Jerret
    North Carolina
    Are you running a GM 1 wire? What is required on that swap?
  6. Nov 28, 2013 at 8:45 AM
    #66
    jerretxx
    Jerret
    North Carolina
    I dont think the 85 will mount on my truck, the bracket is different.
    85:
  7. Nov 28, 2013 at 8:46 AM
    #67
    ajohnson
    Andy
    Charlotte, NC
    Yea, well mine is technically 2 wires. It's a powermaster 100 amp 12si, mounted with a Trail Gear mount. I got a harness plug from napa and spliced it into the factory wires leaving one factory wire (white I think) unused, and 8 gauge wire straight to the battery. The hardest part was swapping the mounts.
  8. Nov 28, 2013 at 8:54 AM
    #68
    ajohnson
    Andy
    Charlotte, NC
    I might have my mount too. Have to check when I get home.
  9. Nov 28, 2013 at 8:58 AM
    #69
    jerretxx
    Jerret
    North Carolina
    I think the external voltage regulator may be my problem. The old alternator was bad as well, bearing had a ton of play in it. Do you know if there are any fuses related to the alternator in the harness? There is not on in my fuse panel.
  10. Nov 28, 2013 at 9:13 AM
    #70
    ajohnson
    Andy
    Charlotte, NC
    Fuses under the dash, too. If all the fuses are fine I would assume the regulator is bad. If that's the case go ahead and upgrade, wether its just a newer internally regulated unit or a higher output GM setup. You can have my mount and alternator if you want.
  11. Nov 28, 2013 at 11:49 AM
    #71
    jerretxx
    Jerret
    North Carolina
    I looked in the panel under my dash and there is everything except alternator. My neighbor has a toyota grave yard, may just snag a voltage regulator off of it just I see if it will work.
  12. Nov 28, 2013 at 12:22 PM
    #72
    ajohnson
    Andy
    Charlotte, NC
    I read somewhere that it's the same fuse as the fuel gauge? Can't say how true it is. Anyway good look getting it going. Let me know if you want my parts, no purchase necessary. Happy thanksgiving bo.
  13. Nov 28, 2013 at 12:42 PM
    #73
    jerretxx
    Jerret
    North Carolina
    Ill do it pal, I am going to take you up on the extra parts. Id like to have them as backup. I hope a voltage regulator will get me going for now, and i can grab that other alt and bracket the 14th unless I end up needing it sooner. Happy thanks giving to you and your family as well
  14. Nov 28, 2013 at 12:45 PM
    #74
    ajohnson
    Andy
    Charlotte, NC
    Awesome, just remind me.
  15. Nov 28, 2013 at 6:40 PM
    #75
    jerretxx
    Jerret
    North Carolina
    do you have the other angle?
  16. Nov 28, 2013 at 7:02 PM
    #76
    ajohnson
    Andy
    Charlotte, NC
    The pic? Nah just that angle. Good times!
  17. Nov 28, 2013 at 8:00 PM
    #77
    jerretxx
    Jerret
    North Carolina
    that was wild. Great times
  18. Dec 3, 2013 at 5:54 PM
    #78
    jerretxx
    Jerret
    North Carolina
    Finally got the truck straightened out. Just need to reinstall the rear shocks and I'll be back on the trail
  19. Dec 5, 2013 at 1:08 PM
    #79
    mipawlus
    mipawlus #332 Veteran Overland, #159 TTC, #69 in your heart
    Captain Poopypants
    Aggieland
    BROJAHAHAHAHA!!!!
    Rust and dents and squeaks
    good god man, you need TW anonymous meetings! good stuff though!
  20. Dec 6, 2013 at 7:20 PM
    #80
    jerretxx
    Jerret
    North Carolina
    Shocks are back on! shes ready to ride again
