Jerry (gas) can under tonneau cover?
Discussion in 'Tonneau Covers, Caps and Shells' started by DevL, Aug 12, 2010.
  1. Aug 12, 2010 at 6:29 PM
    DevL
    DevL [OP] Well-Known Member
    Is there a way to secure a Jerry can or NATO gas can or other 5 gal gas can in the bed, upright, and under a soft tonneau cover?
  2. Aug 12, 2010 at 7:49 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Is there a way to get at the rails. Drill a hole and slide in a eye bolt. Use a "Spring Nut " minus the spring, just snap it off for inside the rail.
    A Unistrut nut. They also make a smaller tie point that is good for 100 ibs from Toyota. Just drill a hole to get at the rail. I'm assuming it's like mine with a steel cover over the rails for the tonneau cover mount.
    http://www.tacomapartsstore.com/product_info.php?products_id=752
  3. Aug 13, 2010 at 1:58 PM
    EricGagne
    EricGagne Well-Known Member
    Eric
    Montreal
    2010 TRD Off Road
    Literider Tonneau Cover, RAM Mount Laptop Support. Uniden CB RTT and awning with self-designed custom rack Dual battery system - National Luna solenoid and monitor, Columbia Overland dual battery tray, 2 Odyssey PC1200 12 circuits Fuse block with 80A macro fuse block "breaker" OME suspension Replaced passenger area with a flat platform for my ARB fridge and camping clothes. Tiregate HG series
  4. Mar 5, 2011 at 10:37 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
