Jet Mass air sensor
Discussion in 'Product Reviews' started by Futral, Jan 1, 2016.
  1. Jan 1, 2016 at 3:13 PM
    Futral
    Futral [OP] Member
    Dan
    Pocatello, Idaho
    2014 double cab Tacoma
    K&N, flow master 40 series, 265 MT tires, 28" led lightbar
    A friend of mine has a 13 Tacoma and bought one of the Jet Mass Air Sensors and he claims he gets 2-3 more MPG since install. I just don't see how this is possible so I'm reaching out to see if any of you have installed one. If you have, did you notice any difference? They're only like 150 and if I will get a mileage gain then it may just be worth it to me. Thanks!
  2. Jan 1, 2016 at 3:16 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Jan 1, 2016 at 3:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If it adjusts the reading of the g/s of air that the computer is seeing, there is a possibility. Does it? I do not know.
    Justus likes this.
  4. Jan 1, 2016 at 3:24 PM
    Futral
    Futral [OP] Member
    Dan
    Pocatello, Idaho
    I've read quite a bit on it and there is nothing that says it's any different than OEM. Just Jet making claims of gains but it doesn't say how the gains are made
  5. Jan 1, 2016 at 3:25 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    just like a throttle body spacer for 2nd gens.
  6. Jan 4, 2016 at 10:11 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
