Jetski help
Discussion in 'General Automotive' started by BlueTaco07, Jun 13, 2011.
  1. Jun 13, 2011 at 1:32 PM
    BlueTaco07
    BlueTaco07 [OP] Super Mod!
    Cody
    Panama city, Florida
    Looking
    Okay so I have a 2002 yamaha xl700 2 stroke waverunner. New spark plugs. Replaced carbs. Batterys good. Full tank of gas and oil. Today I sprayed carb cleaner into the carbs and cranked it. It starts for a second or two then cuts off. Could this be a bad fuel line or filter? Any input is great.
  2. Jun 13, 2011 at 1:37 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Carb may need some adjustment.
    Replacing the fuel filter is a cheap easy solution. No harm in doing that.
    Also may be a bad fuel pump.
    I'm glad I got rid of my PWC (Sea-Doo) that thing was such a pain the asss.
  3. Jun 13, 2011 at 1:39 PM
    BlueTaco07
    Cody
    Looking
    x2 I got the carb settings adjusted. Possible fuel pump because I diconnected the Fuel line off the fuel filter and started and no gas was comming out. so Im kinda confused...
  4. Jun 13, 2011 at 1:41 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    How long was it sitting? Could definitely be bad fuel or a plugged filter. Always a good idea to replace everything since it's usually pretty cheaper and a hell of a lot easier than rebuilding a carburetor.
    Bad gas has a stale smell to it. Smell it once and you'll never forget it.
    I'm assuming the fuel pump has checked out as good?
    Good luck on the resurrection!
  5. Jun 13, 2011 at 1:45 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    mine did the same thing then it blew up but every jet ski has a shelf life of about a year with me so it was about time
  6. Jun 13, 2011 at 1:47 PM
    BlueTaco07
    Cody
    Looking
    Gas was just put in a week or so ago. And no the fuel pump is unknown right now Ill have to find it once this storm passes
