Jiffy Lube for Differential Fluid exchange
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScrippsRanch67, Feb 7, 2024.
  1. Feb 8, 2024 at 3:39 PM
    TacoTuesday1
    SD CA
    only the best.
    drain the trans double fill the engine
    cut hole in skid shield
    ship car with no motor oil
    Those are good too
    JustADriver likes this.
  2. Feb 12, 2024 at 10:37 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. Feb 12, 2024 at 10:58 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    So you're saying Jiffy Lube is up there with Toyota ExpressLube quality? Oh wait, you didn't mention the oil bottle jammed against the fan belt, only the dealer does that.
  4. Feb 12, 2024 at 2:11 PM
    TacoTuesday1
    SD CA
    Jiffy lube and dealer express lube are both lube.
    not every dealer runs express that way. Some don’t have it express at all.
  5. Feb 12, 2024 at 3:48 PM
    OffroadToy
    That's a good thing... your gonna need it before they get though with you! :eek:
  6. Feb 12, 2024 at 9:45 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    NO WAY, Do it yourself,it's easy.
  7. Feb 12, 2024 at 10:16 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Google says the average Jiffy Lube technician gets paid around $14/hr (median). Consider someone at Wendy’s making your burger could be taking home $15/hr well that should speak volumes. Anecdotally I’ve had two relatives drive away and grenade their engine because techs failed to complete the job properly (surprisingly one caused by a finger-tight drain plug rather than the opposite 600 lb-ft ugga-dugga strip job). Cannot recommend using their services.
    If you can turn a few wrenches and are physically able, do it yourself. Really isn’t that hard and a great place to start learning about DIY maintenance. Else find a reputable local non-speedy-drivethru mechanic that won’t F it up.
    ScrippsRanch67[OP] likes this.
