Jimbos Rig #OLAF AF
Discussion in '2nd Gen. Builds (2005-2015)' started by JimboAnz, Jul 31, 2015.
  1. Feb 15, 2018 at 3:27 PM
    #541
    JimboAnz
    JimboAnz [OP] #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Cool. Thx. Similar numbers, similar miles :thumbsup:
    mcharfauros and ChadsPride like this.
  2. Feb 19, 2018 at 4:13 AM
    #542
    JimboAnz
    Jimbo
    Replaced my driver side needle bearing this weekend, as well as @Bannerman 's. We did well, out and in, in about 3 hours total. we both had to learn on the fly. no issues.
    comparison of our 2 bushings. both trucks are 2015.
    His truck has about 60K and lifted since 25K, symptoms since lift.
    Mine has 102K, lifted since 20K, I did not exhibit symptoms.
    His is the lower one in the pic, mine is upper. All trucks are different, and why this does, or does not happen is random to me.
    This is a great video, showing the process, and we found this method to remove (and install) the CV axle (5:37) to work great. https://youtu.be/m9W31KGy6k0
  3. Feb 19, 2018 at 6:42 AM
    #543
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    Good stuff! It is crazy how the same truck can act so different. My vibes started right after the lift was installed.
    Did you make sure you got the the broken lip of the needle bearing out? That normally happens during the removal of the bearing and would be bad if it found its way back into the diff.
    JimboAnz[QUOTED][OP] likes this.
  4. Feb 19, 2018 at 6:44 AM
    #544
    JimboAnz
    Jimbo
    yeah, no. we fished with the magnet on a stick for it, no luck. hopefully its stuck to magnet on the drain plug. :anonymous:
    stronghammer likes this.
  5. Feb 19, 2018 at 6:46 AM
    #545
    BamaTaco56
    Trey
    Looks like its about time for him to flush his differentials anyways. Good reason to get it done at a 30k interval.
  6. Feb 19, 2018 at 6:47 AM
    #546
    JimboAnz
    Jimbo
    agreed, I am a fan of 30K fluid swaps :thumbsup:
    BamaTaco56[QUOTED] likes this.
  7. Feb 19, 2018 at 7:15 AM
    #547
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Yeah I did all fluids at 30k, plan to do them all again soon. If I was smarter I would have just done the front diff while I had it apart and with the skid plate off.
    I read back through the TSB this morning and I think I incorrectly told you the lip was damaged on the inside (diff side). It was actually damaged on the outside, which makes sense because it is apparently caused by the CV angle change after lifting.
  8. Feb 19, 2018 at 7:24 AM
    #548
    JimboAnz
    Jimbo
    I had assumed is was damaged on the outside / CV side :thumbsup:
  9. Feb 19, 2018 at 7:26 AM
    #549
    Bannerman
    Johnson
    Charlotte, NC
    My drive up to Morganton was super smooth this morning, glad not to have to worry about that groan anymore. Tested 4x4 too, no issues.
  10. Feb 19, 2018 at 7:27 AM
    #550
    JimboAnz
    Jimbo
    :headbang: awesome. mine feels fine as well. good day yesterday, thanks for hosting :thumbsup:
    Bannerman[QUOTED] likes this.
  11. Feb 26, 2018 at 12:14 PM
    #551
    JimboAnz
    Jimbo
  12. Feb 26, 2018 at 12:16 PM
    #552
    Bannerman
    Johnson
    Charlotte, NC
  13. Feb 26, 2018 at 12:18 PM
    #553
    JimboAnz
    Jimbo
    haha, dang, why? smoke? I am gonna run a 3 pack through over several tanks of gas.
  14. Feb 26, 2018 at 12:23 PM
    #554
    Bannerman
    Johnson
    Charlotte, NC
    Yeah, spray it into the air intake at the throttle body, or suck it up with a vacuum tube. Cleans the intake manifold/valves. But it smokes like hell for the couple miles
  15. Feb 26, 2018 at 12:25 PM
    #555
    JimboAnz
    Jimbo
    ahh, gotcha. I saw that aerosol one, this is the fuel additive one. cleans out the engine internals, supposedly
  16. Feb 26, 2018 at 12:41 PM
    #556
    BamaTaco56
    Trey
  17. Feb 26, 2018 at 12:44 PM
    #557
    JimboAnz
    Jimbo
    i am gonna run 3 cans trough over many tanks of gas, give it a little cleaning out of the gunko.
  18. Feb 26, 2018 at 12:46 PM
    #558
    BamaTaco56
    Trey
    It cleans pretty well.
    I'm about to run a can through my wife's car before her oil change and another through my truck before my next oil change. Advance Auto have a BOGO 50% off deal.
  19. Feb 26, 2018 at 1:33 PM
    #559
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I will be running 1/3 through intake, 1/3 through gas tank, and 1/3 through oil on my Rover. Then change the oil and spark plugs.
    JimboAnz[OP] likes this.
  20. Feb 26, 2018 at 2:09 PM
    #560
    Sammie
    Sammie :D :P ;)
    NC
    ‘17 Tacoma BBP
    When my neighbors do it there's smoke galore
    ovrlndkull and JimboAnz[OP] like this.
