Jingle coming from front left
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AKCanuck, Aug 30, 2024.
  1. Aug 30, 2024 at 9:38 AM
    AKCanuck
    AKCanuck [OP] New Member
    Getting an intermittent jingling (sounds like bells ringing or washers/coins being shook in the palm of your hand) sound coming from the front left side of the truck. 2012 4Dr, w 4L V6.
    Curious if anyone has had the same sound, and what it was diagnosed as? Truck has passed safety inspection in past month, and is generally in great shape. No weird feelings when driving, just the annoying sound. Only can hear it at low speeds with windows down.
    Have peaked around the front left wheel well and behind the wheel to see if anything was loose, but couldn't locate anything.
    Let me know what you guys think.
  2. Aug 30, 2024 at 10:14 AM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    I have the same annoying intermittent jingling. Haven't found the source of mine, kinda difficult to follow the road while poking under the dash.
  3. Aug 30, 2024 at 10:18 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW..any heat shields loose/backing plates...
  4. Aug 30, 2024 at 10:39 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    check the front grill...
    winkel, Slatroni and HondaGM like this.
  5. Aug 30, 2024 at 10:43 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Pads are rattling. LIGHTLY brake, if the sound goes away, it's likely loose pads.
  6. Aug 30, 2024 at 10:48 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    once i left a socket in the caliper cup once from compressing it and made a ringing noise on every bump for 50k miles until i did the brakes. Found my missing 17mm socket after o_O
    fatfurious2 and winkel like this.
  7. Sep 4, 2024 at 1:27 AM
    AKCanuck
  8. Sep 18, 2024 at 2:10 AM
    AKCanuck
