JitmanToyos
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jitman73, Apr 13, 2025.
  1. Apr 13, 2025 at 2:38 PM
    Jitman73
    Jitman73 [OP] New Member
    Artemio
    2002 tacoma
    Body lift
    Installed 33x12.50r20 on 02 Tacoma n front is rubbing..any tips
    N already has 3inch front spacer n 2inch spacer on back.
  2. Apr 13, 2025 at 5:39 PM
    wingnutj468
    wingnutj468 Well-Known Member
    David
    2003 gold doublecab 4x4 2.0
    I’ll answer your question with a few more questions. Are those spacers on the suspension or the wheels? Where is it rubbing? Is it the outside of the tire when turned or the inside? When it’s all said and done, to run that specific tire set up, clearance must be made somehow. Either your truck will need to be lifted more or body work will have to be altered to accommodate. One last question, what is N?
  3. Apr 13, 2025 at 9:22 PM
    Jitman73
    Artemio
    2002 tacoma
    Body lift
    N = and
    spacer is on suspension.
  4. Apr 13, 2025 at 9:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    :sawzall:
  5. Apr 14, 2025 at 11:07 AM
    oldgreg
    oldgreg Well-Known Member
    Greg
    2001 2.7 reg cab 4x4
    Wulf and Laxtoy like this.
  6. Apr 14, 2025 at 4:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How wide are those 20" wheels? What is their offset or backspacing?
  7. Apr 14, 2025 at 4:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If the truck already has 3" of lift up the front, it's already got more than is recommended for the ifs.
