Jl 13.5 subwoofer
Discussion in 'Audio & Video' started by Solid808, Feb 16, 2013.
  1. Feb 16, 2013 at 4:39 PM
    Solid808
    Solid808 [OP] Active Member
    Honolulu
    2013 Tacoma Trd sport
    Ok I decided to get this sub but I dont know which one the 2 ohms or the 4 ohms version. I have a JL HD 900/5 amp and it looks like 4 or 2 ohms is the same power range on the amp. so should I just run the 4 ohms version maybe the amp will run cooler since I am running only one sub? confused
  2. Feb 17, 2013 at 6:12 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Are you ever planning to install a second sub?
  3. Feb 17, 2013 at 8:22 PM
    Solid808
    Honolulu
    Nope just the one
  4. Feb 17, 2013 at 8:24 PM
    sirsaechao
    Tim
    Commifornia
    Then either will do cause the JL amp has RIPS system so same power from 4ohm to 1.5ohm.
