JLee's Build
Discussion in '1st Gen. Builds (1995-2004)' started by JLee, Sep 20, 2010.
  1. Sep 2, 2013 at 10:50 PM
    #3381
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Ho damn! Last weekend, we were on Signal and camped at Pierce Creek.
  2. Sep 3, 2013 at 2:58 AM
    #3382
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    Did you wheel over there or just camp?
  3. Sep 3, 2013 at 6:28 AM
    #3383
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah i saw you guys i recognized the white one.
  4. Sep 3, 2013 at 6:39 AM
    #3384
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Oh nice!
    I camped at Cisco Grove with my travel trailer. I was about an hour away from camp and got stuck in some deep mud in front of Sterling Lake. Had to get the campsite's owner to tug me out after being stuck for several hours. Now that I think about it, I shoulda called you Jerry! I had to pay a pretty penny for him to come all the way out to tug me out :(
    But yea on the way out, there were a bunch of rigs (jeeps and toyotas) on trailers heading to Fordyce from that way
  5. Sep 7, 2013 at 1:21 PM
    #3385
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    DAMN!! your rig is ridiculous!! awesome work
  6. Sep 15, 2013 at 1:35 PM
    #3386
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
  7. Sep 25, 2013 at 10:00 AM
    #3387
    cynicalrider
    cynicalrider #NFG
    Jersey
    Since I'm a month behind in this build thread, subbing for future reading. Truck looks so mean.
  8. Sep 30, 2013 at 3:07 PM
    #3388
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Jerry, have you done much tuning with the ORI's? Curious about your PSI numbers and what not.
  9. Sep 30, 2013 at 10:52 PM
    #3389
    JLee
    Jerry
    Benicia, CA
    No i havent really i'm running 100psi in the front lower chambers and somewhere around 350 in the uppers. The rears i'm running just under 300 in the uppers and 0psi in the lowers at the moment. I'm messing with the lower pressure in the rear 10lbs at a time running it for a few days and seeing how i like the ride. The rear end is light and bucks around when ran at 100 like the fronts.
  10. Oct 2, 2013 at 7:02 AM
    #3390
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Isn't the lower your bumpstop? Good to know on the fronts :cool:
  11. Oct 2, 2013 at 9:05 AM
    #3391
    JLee
    Jerry
    Benicia, CA
    Spring rate and bump stop.
  12. Oct 3, 2013 at 12:15 PM
    #3392
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    how's the rig been? you been able to get out wheeling lately?
  13. Oct 3, 2013 at 1:03 PM
    #3393
    JLee
    Jerry
    Benicia, CA
    I guess i can give a report.
    I've driven it 5000 miles and it drives nice On and off road. I shortened the upper link in the rear and moved the axle forward 1.5" to help clear the fenders and get a better pinion angle. I've burned the brake pads on all 4 corners (I have a right pads now :eek:) replaced the 2 front rotors. Having issues with the Yukon hubs lot disengaging every time i unlock them. My lower link crossmember needs to be welded on there is too much movement being bolted. My T case is leaking as well as both diffs "easy fix just haven't found the time". I may need a bed cage the rear frame flexes quite a bit at high way speeds with a load.
    I have only hit 2 trails and it did great! I climbed everything in my path Just a few little things I need to do to help it slide over rocks better the link mounts got hung up more then a few times on both trails. I was going to hit the Con last weekend but work got in the way. I still haven't really challenged the truck yet I'm sure MOAB next year with be the first not much more wheeling here left before the season is done.
  14. Oct 3, 2013 at 1:08 PM
    #3394
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    excited to see the beast in person
  15. Oct 15, 2013 at 11:44 AM
    #3395
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    so i know you got new pictures, post them
  16. Oct 17, 2013 at 6:03 PM
    #3396
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    Awesome build man
  17. Oct 17, 2013 at 6:26 PM
    #3397
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Truck is to epic for mere pictures...
    There needs to be a statue erected to proclaim it's magnificence! :cool:
  18. Oct 17, 2013 at 9:19 PM
    #3398
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    Of all the awesomeness in this build, yes I am going to ask about the headlights. What projectors did you use and can you post some pics of that mod?
  19. Oct 18, 2013 at 5:29 AM
    #3399
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Go to theretrofitsource.com
    I'm pretty sure his are either H1 or D2S minis but may be the FX-Rs. Either way those are the main three people get. PM me or call them up if you want more details on each option. They have phenomenal customer service I'm comparison to what I usually get elsewhere.
  20. Oct 18, 2013 at 6:44 AM
    #3400
    JLee
    Jerry
    Benicia, CA
    They are the mini's and i didn't take any pictures the light output is amazing.
