JLee's Build
Discussion in '1st Gen. Builds (1995-2004)' started by JLee, Sep 20, 2010.
  1. Oct 18, 2013 at 10:27 AM
    #3401
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    Mini's got it. Actually used the search function and researched it last night. It looks like you have the Apollos with Angel eyes if I'm not mistaken right? Those look good in the smaller first gens. Did you modify them or just installed them as is?
  2. Oct 18, 2013 at 10:32 AM
    #3402
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Mini Gatling shrouds and white angel eyes. I did trim the shrouds to fit the angel eyes in the shroud and not on top of ti but that's all I did.
  3. Oct 18, 2013 at 2:30 PM
    #3403
    yf19
    Phoenix AZ
    Awesome thanks. After I get my new set of tires I'll order a set of your first gen Ex-Cab sliders.
  4. Nov 13, 2013 at 8:33 PM
    #3404
    JLee
    Jerry
    Grass valley CA
    A little update on the truck last month my crawl box tossed a bearing in the output and made a metal milk shake :( the truck has been sitting in the shop for a month. Its all back together now and I did a little beefing up on the lower link crossmember. it moved and bent the mounting bolts jumping the truck over the summer so I decided to weld it in. I also added 1.5" x.250 wall DOM to the back of it connecting it to the rear lower mounts. Now the truck wont get caught up on the rear lower link mount if I'm sliding over the rocks.
  5. Nov 13, 2013 at 8:44 PM
    #3405
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    So you will be all set for the snow? :)
  6. Nov 13, 2013 at 8:45 PM
    #3406
    JLee
    Jerry
    Grass valley CA
    I'm set!!
  7. Nov 13, 2013 at 8:47 PM
    #3407
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Huh..your the 3rd guy i know in the last month who's crawl box bearing took a shit..
  8. Nov 13, 2013 at 8:54 PM
    #3408
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    Was going to post in here to see if you got her fixed.:eek: glad it's back together
  9. Nov 13, 2013 at 9:26 PM
    #3409
    JLee
    Jerry
    Grass valley CA
    Yeah I guess it was a batch of plates they had with a bad tolerance they had a bunch doing the same thing. Mine was fully replaced only the adaptor plates were reused as it got pretty beat up. I was in wells NV when it happened and had to drive the truck 500 miles home holding it in gear :(
  10. Nov 13, 2013 at 9:28 PM
    #3410
    JLee
    Jerry
    Grass valley CA
    Yeah its all good now I drove it home for first time tonight.
  11. Nov 13, 2013 at 9:31 PM
    #3411
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn. Shitty timing.
  12. Nov 13, 2013 at 9:35 PM
    #3412
    JLee
    Jerry
    Grass valley CA
    Your telling me with my wife and 5 month old son in the truck. I'm just glad we made it home without too many set backs.
  13. Nov 13, 2013 at 9:45 PM
    #3413
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    dam thats rough man! Bad luck there. Nice to see it all got taken care of though!
  14. Nov 13, 2013 at 9:47 PM
    #3414
    JLee
    Jerry
    Grass valley CA
    Yeah the guys at marlincrawler turned it around in 2 days.
  15. Nov 13, 2013 at 9:49 PM
    #3415
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    so did you camp out there/get a hotel and play around while they fixed it?
    guess thats what happens when you drive your crawler to go play lol
  16. Nov 13, 2013 at 9:52 PM
    #3416
    JLee
    Jerry
    Grass valley CA
    Nope I drove it all the way home and pulled the box that next weekend. It just wanted to jump out of gear so it drove fine as long as I was holding the shifter.
  17. Nov 13, 2013 at 9:55 PM
    #3417
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    That is a journey I would not want to make holding a gearshift. Glad you guys made it home OK!
  18. Nov 13, 2013 at 9:55 PM
    #3418
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh oh oh ok. duh.
    didnt have a rope or a bungee to hold it in place ha?
  19. Nov 13, 2013 at 10:35 PM
    #3419
    JLee
    Jerry
    Grass valley CA
    I had one ratchet strap and it wss holding my tire on the rack :( I should of stopped and bought more.
  20. Nov 14, 2013 at 6:15 AM
    #3420
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I am having the same issue Jerry. I am looking at different bearing options. There's several threads about it on TTORA. Glad to hear they covered it. I haven't pulled it apart yet, but mine is making the same noise as everyone else's that spit the balls out :(
