JLee's Build
Discussion in '1st Gen. Builds (1995-2004)' started by JLee, Sep 20, 2010.
  1. Mar 9, 2014 at 7:58 PM
    #3521
    Humboldtmx
    Humboldtmx Active Member
    Mitch
    Mckinleyville CA
    2001 white tacoma, xtra cab ,3.4 v6
    stock muffler dual out, 33" toyo mt's, rough country AAL, bilstein 5100's at 2.5, ebay grill, red TRD decals, BFH! to cab mod, rmx monotude rear shocks(junk), custom delta toolbox(1) regular lo-pro delta(2), and weather guards for windows.
  2. Mar 9, 2014 at 8:10 PM
    #3522
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    Can't wait to see this beast in action
  3. Mar 15, 2014 at 8:10 PM
    #3523
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Did a little work on the truck today. Just maintenance oil and tires lubeed the links and I thought I had a issue with one of the link bolts being wallowed out but come to find out I need to replace my clutch :(. Now im resurching what one I want to put in the truck I know im going high performance stage 3 most likely just what brand is the question.
  4. Mar 15, 2014 at 8:17 PM
    #3524
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Is the supercharger still doing the trick?
  5. Mar 15, 2014 at 8:21 PM
    #3525
    JLee
    Jerry
    Grass valley CA
    Oh yeah!!
  6. Mar 15, 2014 at 9:50 PM
    #3526
    JLee
    Jerry
    Grass valley CA
  7. Mar 16, 2014 at 2:51 AM
    #3527
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    What do you think about the Marlin crawler heavy duty clutch?
    I was thinking about picking up the 1200 pound one. It seems to be quite a bit cheaper compared to what you have posted, are the advantages to what you posted Weyworth it?
  8. Mar 16, 2014 at 5:00 AM
    #3528
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    If the URD one maintains the stock pedal feel, I'd look at that one.
    Nothing sucks worse than driving in traffic with a stiff pedal.
  9. Mar 16, 2014 at 5:34 AM
    #3529
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I'm so pleased. Right on.
  10. Mar 16, 2014 at 7:01 AM
    #3530
    JLee
    Jerry
    Grass valley CA
    I want holding power with 37's 5.29 gears and the SC I need it to hold when i stab it. The marlin has a 33% over stock holding power and the CC has a 180% the torque capacity then stock. Also marlin don't have any for the 3.4l from what I can see. Price is not an issue at this point.
    Yeah I'm leaning towards that one I'm Going to call gadget tomorrow and see what he thinks is the right one for my setup.
  11. Mar 16, 2014 at 7:46 AM
    #3531
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Ummm..I think you might misunderstand the point of a flywheel. With your monster tires you want a heavier flywheel, not lighter. Heavier flywheel means more inertia and keeps the engine RPM up when shifting gears. A lighter flywheel will be less inertia and will drop RPM faster when shifting gears, typically used in drag racing. Yes it's less rotating mass so the engine will spin up faster, but shifting gears is going to suck.
    Whatever you chose, check out LCEngineering. They have both a heavy 38 lb steel and a lightened 13 lb aluminum flywheel for the 5vz.
  12. Mar 16, 2014 at 7:54 AM
    #3532
    JLee
    Jerry
    Grass valley CA
    That's what I needed to here everywhere I read it's lighter lighter lighter but that's all cars.
  13. Mar 16, 2014 at 8:06 AM
    #3533
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Think of it this way. You have 37" tires. When you rev your truck to about 2k rpm and dump the clutch, it wants to bog down fast, if not stall. If you do the same thing with a lighter flywheel, the flywheel has less moving inertia and the truck will be even more likely to stall. On the contrary side, a heavier flywheel will store more energy and that stored energy will transfer to the tires. It just takes a little more effort to get the engine up to the same RPM range with a heavier flywheel, but the engineis more likely to stay up in that RPM range once you get there.
    General rule of thumb, if you're shifting gears a lot because of hard accelerations/decelerations (track/road racing, drag racing, circle track, etc), you want a lighter (and aluminum) flywheel. Since you own a TRUCK...and a more of a crawler at that (37's, twin cases), the last thing you want is your engine to drop RMP's faster when having to shift gears. Just my 2cents, but for your truck, I would think you wanted to keep your momentum up on hill climbs.
  14. Mar 16, 2014 at 8:15 AM
    #3534
    JLee
    Jerry
    Grass valley CA
  15. Mar 16, 2014 at 8:25 AM
    #3535
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Might I suggest you replace your pilot bearing while you have the clutch out. It's right there once you pull the clutch off.
  16. Mar 16, 2014 at 8:30 AM
    #3536
    JLee
    Jerry
    Grass valley CA
    Yep will do anything else that's right there i should know about wile I have it out?
  17. Mar 16, 2014 at 8:31 AM
    #3537
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I learned something.
  18. Mar 16, 2014 at 8:40 AM
    #3538
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Clutch, pressure plate, throwout (release) bearing, pilot bearing, flywheel, and flywheel bolts (properly torqued). I have the clutch alignment tool if you need one.
    Pro-tip...put your pilot bearing in the freezer for an hour or so before installing it. Makes it easier to tap into place without ruining it (don't ask :anonymous:)
  19. Mar 16, 2014 at 8:54 AM
    #3539
    JLee
    Jerry
    Grass valley CA
    Noted the clutch kit comes with all that.
  20. Mar 16, 2014 at 9:14 AM
    #3540
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    The heavier flywheel is money, and you're going to love it. When your clutch engages and the power hits your transfer case without bogging down the motor it's night and day. I bought one from LCE for the 2.7 (was doing a new clutch anyway) and would rank that mod as a must, with the most driver satisfaction.
