JLee's Build
Discussion in '1st Gen. Builds (1995-2004)' started by JLee, Sep 20, 2010.
  1. May 7, 2014 at 7:35 PM
    #3561
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    damn that shit is toast!
  2. May 7, 2014 at 7:37 PM
    #3562
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    145,000 miles yeah its due for a replacment.
  3. May 7, 2014 at 7:56 PM
    #3563
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Yah think? LOL.
  4. May 8, 2014 at 5:51 PM
    #3564
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    looking forward to your review Jerry. Im looking for something just a touch stiffer than oem. obviously my trucks not charged and geared so that may be a bit much for mine....
  5. May 8, 2014 at 7:35 PM
    #3565
    JLee
    Jerry
    Benicia, CA
    I'll let you guys know what I think of it. I got it all bolted back up today the ultra black on the T case is setting up over night so the first drive will be tomorrow. I will tell you this the clutch peddle feels near stock maybe a little stiffer. I have a new master, slave and SS line so that could change it a little as well i would think.
    I have to brake it in for about 500 to 750 miles so it will be taken easy for the first week or so.
  6. May 8, 2014 at 7:39 PM
    #3566
    lotsoftoys
    Jace
    Denver
    bunch of crap
    cool sounds good
  7. May 8, 2014 at 8:11 PM
    #3567
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Too bad I've got a new OEM flywheel sitting in the garage waiting for install. I'd be interested in trying out that heavy flywheel. Going to check in to see how it rates.
  8. May 8, 2014 at 8:13 PM
    #3568
    JLee
    Jerry
    Benicia, CA
    Yeah I'm looking forward to seeing how it drives with it :D
  9. May 8, 2014 at 10:37 PM
    #3569
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    Jerry I also just installed the same clutch you did about a month ago. I previously had the heavy-duty marlin clutch. I will tell you at this clutch grabs 100 times better than the Marling clutch does. I love this clutch way more than the marlin. Way more expensive but definitely worth it.
  10. May 8, 2014 at 11:21 PM
    #3570
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have the TG HD ceramic clutch and it's nice. Due have to drive it different but once adjusted it's nice.
  11. May 9, 2014 at 5:50 AM
    #3571
    JLee
    Jerry
    Benicia, CA
    good to know ! Do you have the heavy flywheel as well?
  12. May 9, 2014 at 6:03 AM
    #3572
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    The engine, tranny, and transfer case all just connect via splined shafts and are bolted together? I have oil dumping from the rear main seal on my 82 and have never pulled a tranny or clutch before. Trying to get an idea of how hard it will be to drop it all. I also just have a floor jack so I'm wondering if you had any advice on how to get it on the floor and not on my face. Thanks!
  13. May 9, 2014 at 6:14 AM
    #3573
    JLee
    Jerry
    Benicia, CA
    no splines on the back of the engine the flywheel just bolts to it and the splines are only in the clutch and the trans. And it was not bad at all it took a long time but I was fabbing shit on the frame that couldn't get to before so I knocked it out with the trans out. It took me 3 hours to pull everything and the hole next day to have it all back in but I did lots of other little things to the truck that made it take more time.
  14. May 9, 2014 at 6:23 AM
    #3574
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    That doesn't sound too bad. Did you drop it all with a regular floor jack? Getting it down safely is the part I'm worried about.
  15. May 9, 2014 at 6:34 AM
    #3575
    JLee
    Jerry
    Benicia, CA
    I made a cradle that bolts to my floor jack out of scrap tube took about 10 min to do and it was super stable.
  16. May 9, 2014 at 6:44 AM
    #3576
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Got any pics of it? I've got some scrap that might could work
  17. May 9, 2014 at 6:49 AM
    #3577
    tomtom
    The Desert SW
    2012 FJ
    Dropping a transmission with a regular floor jack is a pain and easy enough to have it fall. Definitely take the time to build a cradle like JLee did or get a transmission jack.
  18. May 9, 2014 at 6:58 AM
    #3578
    MJonaGS32
    MJ
    SF Bay Area (East)
    motorcycle jack works well too :D
  19. May 9, 2014 at 7:02 AM
    #3579
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Hmmm my pops might have one too
  20. May 9, 2014 at 7:08 AM
    #3580
    JLee
    Jerry
    Benicia, CA
    Here is what I made its 2x1x.120 wall and 3/16th plate.
