JL's garage of misfit toys and other BS
Discussion in '3rd Gen. Builds (2016-2023)' started by jlusmc, Oct 6, 2017.
  1. Oct 27, 2020 at 6:43 PM
    #901
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Surfside Green would be cool. Mystic Purple is another 98-99 rare one. What was the truck from factory?
  2. Oct 27, 2020 at 6:44 PM
    #902
    jlusmc
    jlusmc [OP] Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
    it was originally white, then later rattle can black and probably without any surface prep because it flakes off in places and the white is still shiny underneath.
  3. Oct 29, 2020 at 7:33 AM
    #903
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Pics of the finished bedliner
  4. Oct 29, 2020 at 7:35 AM
    #904
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Morning James glad to see your making progress on the truck.
  5. Oct 29, 2020 at 7:36 AM
    #905
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Morning to you as well. I have too many projects and kept pushing it back, it was past time to get going on it again.
  6. Feb 10, 2021 at 5:06 PM
    #906
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Started working on Project 97 again, ran into an intermittent starting problem. Have power at the ignition and all dash and accessories work but it will not start and makes no clicking noise. After some investigating and questioning other TW members ( @Bigdaddy4760 @Kanyon71 @Beretta4x4 @MattCowsmasher ) I took some advice moderately tapped the starter with a small hammer and walla.... it started up. After a few starts and stops the problem raised itself again and once again a few taps with the hammer got it starting. As a result I have ordered a new starter. Went with the cold package version (it has a higher torque output for cold morning starts). Starter should be in this Friday so hopefully I'll get it in before the weather gets nasty. Expecting temps in the teens and snow/ice over the weekend.
  7. Feb 10, 2021 at 5:12 PM
    #907
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    :fistbump::bananadance:
    MattCowsmasher and Bigdaddy4760 like this.
  8. Feb 10, 2021 at 5:28 PM
    #908
    Bigdaddy4760
    Maner
    Poolville Texas
    Good deal
    MattCowsmasher and Beretta4x4 like this.
  9. Feb 10, 2021 at 5:37 PM
    #909
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Awesome can’t wait to see it all finished up.
    Beretta4x4 and Bigdaddy4760 like this.
  10. Feb 22, 2021 at 5:28 PM
    #910
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Well now that TX has thawed out for a day or two, I was finally able to get the new starter put into the Tacoma. Worked like a champ, kicks over with every bump of the key. also found a few loose bolts under there and tightened them dudes up. Have noticed it's got a rough idle and sounds like it's gonna die on ya (but doesn't). Hoping that is just a byproduct of old gas. It's pretty much been sitting since October and hasn't had new fuel since August.
  11. Feb 22, 2021 at 5:31 PM
    #911
    Bigdaddy4760
    Maner
    Poolville Texas
    Glad ya got it fixed. Time to get that thing out. You going to jambo
    jlusmc[QUOTED][OP] likes this.
  12. Feb 22, 2021 at 5:33 PM
    #912
    04Pre_Runner
    Andrew
    When disconnecting the battery on my 99 it idles low/rough for about 150 miles until the computer steps in and adjusts. My 04 doesn't do it nearly as bad though because the throttle body isn't worn or dirty.
  13. Feb 22, 2021 at 5:33 PM
    #913
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    I am planning on it, got registered and such. Just need to get the days off. Also helps that on the 25th (Thurs) my office starts working 4/10's and I'll have F-S-S off as my normal schedule.
    Bigdaddy4760[QUOTED] likes this.
  14. Feb 22, 2021 at 5:34 PM
    #914
    Bigdaddy4760
    Maner
    Poolville Texas
    That’s great. Is the truck painted now
  15. Feb 22, 2021 at 5:36 PM
    #915
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Good info, thanks. Prob still gonna drain and refill with new fuel.
  16. Feb 22, 2021 at 5:39 PM
    #916
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Nope, looks about like when I got it. Want to get it on some real trails to see if I have any clearance issues before putting uncut fenders back on. Plus Jambo can be hard on body panels if you do any of the harder trails (which I plan on attempting if all holds well).
    I do have new doors, fenders , grille and marker lights ready to go on though.
  17. Feb 22, 2021 at 5:40 PM
    #917
    04Pre_Runner
    Andrew
    Mines been sitting since late July with a can of seafoam. I’ll be doing that as well probably.
  18. Feb 22, 2021 at 5:41 PM
    #918
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Yeah wish I had thought of that back in August. I put it in my boat, just didn't think the Yota was gonna sit this long.
  19. Feb 22, 2021 at 5:44 PM
    #919
    Bigdaddy4760
    Maner
    Poolville Texas
    Cool sounds like a great plan
  20. Aug 28, 2021 at 5:39 PM
    #920
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Happy birthday, big dawg!
    jlusmc[OP] likes this.
