Joint greasing.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silence9, Jan 4, 2014.
  1. Feb 15, 2014 at 9:25 PM
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    Same as others I grease mine every oil change. front DS u-joint closest to transfercase is a bitch to get at, I usually get grease all over, PITA.
  2. Feb 16, 2014 at 2:27 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Being on the road I had Walmart do an oil change for me. They claimed to have greased four out of the five zerks. I'm guessing they missed the front drive shaft since I have the BudBuilt skids on it.
    $55 with Mobil1 regular synthetic/Fram filter. The dopes did manage to lose the nipple under the oil filter pan. My fault, I should have told them to make sure to NOT lose it, or took it off myself beforehand. To their credit, they did know to put a catch can underneath . . . .
  3. Feb 16, 2014 at 2:44 PM
    monkeyface
    Colorado
    I think lithium-based is typically what you get with grease gun inserts. It's not the white lithium that you see so much, but a darker brown color or gray. What the difference is between the white and the darker color I see from my gun inserts, I don't know . . .
  4. Feb 16, 2014 at 5:56 PM
    Silence9
    Silence9 [OP] Solve et Coagula
    Alberta, Canada
    Alright so any lithium grease will do? Does Toyota have any sort of spec?
  5. Feb 17, 2014 at 1:01 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This: NLGI #2 lithium grease.
  6. Feb 17, 2014 at 1:32 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Pick your favorite brand of oil and run their grease.
  7. Apr 7, 2014 at 9:43 PM
    Silence9
    Alberta, Canada
    Greased 'em all up nice. I finally had time to do the 4x4 ones. The one second in from the front of the truck was the hardest. A bit of ninja skills and I got to it without removing the plate. Thanks again for the info!
