Jointed drive shaft install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skeeter_wv, Mar 23, 2022.
  1. Mar 23, 2022 at 11:25 AM
    Skeeter_wv
    Skeeter_wv [OP] Member
    Eli
    2006 Tacoma SR5 V6 4.0L 4 wd access Cab
    So I broke my drive shaft in 2 places and have ordered a new OEM driveshaft to replace it. I unfortunately have no idea how to line up the drive shaft with the transmission and rear differential since both ends have moved independently. Can't seems to find any videos or threads about this so any help is great!
    Thanks.
  2. Mar 23, 2022 at 11:34 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Put the e brake on. Rear diff flange -> attach -> center support bearing -> attach -> have truck in neutral, rotate output flange -> attach.
    Geeves77 likes this.
  3. Mar 23, 2022 at 11:36 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  4. Mar 23, 2022 at 11:39 AM
    Skeeter_wv
    Eli
    I guess I'm understanding that. As long as the u joints are aligned within 3 degrees and the drive shaft is balanced then it doesn't matter the position of the transfer case compared to the rear diff.
  5. Mar 23, 2022 at 11:39 AM
    Skeeter_wv
    Eli
    Helpful. Thanks pal
  6. Mar 23, 2022 at 12:40 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    @Skeeter_wv If the driveshaft came assembled, I’m pretty sure it’s balanced and in phase. Don’t think they’d be in business long if you have to re-do their work.
    Skeeter_wv[OP] and Geeves77 like this.
  7. Mar 25, 2022 at 8:49 AM
    Skeeter_wv
    Eli
    Great. Thank you. That is what I was sweating.
