Joke of the Day
Discussion in 'Off-Topic Discussion' started by gdawg25, Feb 14, 2007.
  1. Oct 1, 2011 at 9:41 AM
    #1641
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    1. DRILL PRESS : A tall upright machine useful for suddenly
    snatching flat metal bar stock out of your hands so that it
    smacks you in the chest and flings your beer across the
    room, denting the freshly- painted project which you had
    carefully set in the corner where nothing could get to it.
    2. WIRE WHEEL : Cleans paint off bolts and then throws them
    somewhere under the workbench with the speed of light .
    Also removes fingerprints and hard-earned calluses from
    fingers in about the time it takes you to say, 'Oh shit!'
    3. SKILL SAW : A portable cutting tool used to make studs
    too short.
    4. PLIERS : Used to round off bolt heads. Sometimes used in
    the creation of blood-blisters.
    5. BELT SANDER : An electric sanding tool commonly used to
    convert minor touch-up jobs into major refinishing jobs.
    6. HACKSAW : One of a family of cutting tools built on the
    Ouija board principle... It transforms human energy into a
    crooked, unpredictable motion, and the more you attempt to
    influence its course, the more dismal your future becomes.
    7. VISE-GRIPS : Generally used after pliers to completely
    round off bolt heads. If nothing else is available, they
    can also be used to transfer intense welding heat to the
    palm of your hand.
    8. OXYACETYLENE TORCH : Used almost entirely for lighting
    various flammable objects in your shop on fire. Also handy
    for igniting the grease inside the wheel hub out of which
    you want to remove a bearing race.
    9. TABLE SAW : A large stationary power tool commonly used
    to launch wood projectiles for testing wall integrity.
    10. HYDRAULIC FLOOR JACK : Used for lowering an automobile
    to the ground after you have installed your new brake shoes
    , trapping the jack handle firmly under the bumper.
    11. BAND SAW : A large stationary power saw primarily used
    by most shops to cut good aluminum sheet into smaller
    pieces that more easily fit into the trash can after you
    cut on the inside of the line instead of the outside edge.
    12. TWO-TON ENGINE HOIST : A tool for testing the maximum
    tensile strength of everything you forgot to disconnect.
    13. PHILLIPS SCREWDRIVER : Normally used to stab the vacuum
    seals under lids or for opening old-style paper-and-tin oil
    cans and splashing oil on your shirt; but can also be used,
    as the name implies, to strip out Phillips screw heads.
    14. STRAIGHT SCREWDRIVER : A tool for opening paint cans.
    Sometimes used to convert common slotted screws into
    non-removable screws and butchering your palms.
    15. PRY BAR : A tool used to crumple the metal surrounding
    that clip or bracket you needed to remove in order to
    replace a 50 cent part.
    16. HOSE CUTTER : A tool used to make hoses too short.
    17. HAMMER : Originally employed as a weapon of war, the
    hammer nowadays is used as a kind of divining rod to locate
    the most expensive parts adjacent to the object we are
    trying to hit.
    18. UTILITY KNIFE : Used to open and slice through the
    contents of cardboard cartons delivered to your front door;
    works particularly well on contents such as seats, vinyl
    records, liquids in plastic bottles, collector magazines,
    refund checks, and rubber or plastic parts. Especially
    useful for slicing work clothes, but only while in use.
    19. SON-OF-A-BITCH TOOL : (A personal favorite!) Any handy
    tool that you grab and throw across the garage while
    yelling 'Son of a BITCH! ' at the top of your lungs.
    It is also, most often, the next tool that you will need.
  2. Oct 3, 2011 at 1:17 PM
    #1642
    johneman
    johneman Life is good relaxin' on the porch!!
    Ken
    Warwick,Bucks PA
    2021 TRD OR Magnetic Gray
    Go Rhino Dominator D1 step, Extang Encore Tonneau.
    The Preacher stops in to see 81 year old Edna. She invites him in for a cup of tea and takes him into the parlor. While Edna is brewing the tea, the Preacher is looking around the room and sees a bowl sitting on top of her organ and the bowl is filled with water with a condom floating in it. Edna brings the tea in and after 20 minutes of conversation, the Preacher's curiosity was getting the best of him and he asked Edna about the bowl on the organ....Edna told him "one day while walking in the park I found a package on the ground. When I picked it up and read the directions it said: Put on your organ, keep wet and it's guarenteed to protect you from disease. It really works, I haven't had the flu in 1 1/2 years!!!!"
  3. Oct 3, 2011 at 1:28 PM
    #1643
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    :laugh:
  4. Oct 3, 2011 at 1:37 PM
    #1644
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    I saw a one legged man with no arms at the ATM today.
    He asked me to help him check his balance....
    So I pushed the fucker over.
  5. Oct 3, 2011 at 3:23 PM
    #1645
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Lol!
  6. Oct 3, 2011 at 3:26 PM
    #1646
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    Awesome
  7. Oct 3, 2011 at 6:36 PM
    #1647
    T-Rex266
    Elon
    Wife: there's something preying on my mind.
    Husband: don't worry, it'll die soon
  8. Oct 3, 2011 at 7:34 PM
    #1648
    T-Rex266
    Elon
    Little Jonny and Susan were playing Doctor outside. Susans mom said "your going to get a good licking when ur dad gets home"
    -Jonnys been doing that all day already
  9. Oct 3, 2011 at 7:36 PM
    #1649
    T-Rex266
    Elon
    Why are men's auto insurance rates higher?
    Women don't get BJs while driving
  10. Oct 4, 2011 at 1:51 PM
    #1650
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Doomed from the start
  11. Oct 4, 2011 at 1:54 PM
    #1651
    johneman
    Ken
    Warwick,Bucks PA
    Attached Thumbnails[​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    ^^^^^:rofl::rofl::rofl::rofl:^^^^^^
  12. Oct 5, 2011 at 9:19 AM
    #1652
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Humour - slightly twisted; perfect
    I was devastated to find out my wife was having an affair but, by turning to religion, I was soon able to come to terms with the whole thing. I converted to Islam, and we're stoning her in the morning!
    The wife suggested I get myself one of those dick enlargers, so I did.... she's 21 and her name's Lucy.
    Went to the pub with my girlfriend last night. Locals were shouting "pedophile!" and other names at me, just because my girlfriend is 21 and I'm 50. It
    completely spoiled our 10th anniversary.
    Following the tragic death of the Human Cannonball at the Kent Show, a spokesman said "We'll struggle to get another man of the same calibre."
    My son was thrown out of school today for letting a girl in his class give him a hand-job. I said "Son, that's 3 schools this year! You'd better stop before you're banned from teaching altogether."
    Question - Are there too many immigrants in Britain?
    17% said yes; 11% said No; 72% said "I am not understanding the question please."
    The cost of living has now gotten so bad that my wife is having sex with me because she can't afford batteries!
  13. Oct 5, 2011 at 12:15 PM
    #1653
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Subbed. :D
  14. Oct 5, 2011 at 2:21 PM
    #1654
    T-Rex266
    Elon
    What do u get when u cross Raggedy-Ann with Pillsbury dough boy?
    -a red headed bitch with a yeast infection
  15. Oct 6, 2011 at 6:17 AM
    #1655
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Students at a local school were assigned to read 2 books, 'Titanic' and 'My Life' by Bill Clinton.
    One student turned in the following book report,
    With the proposition that they were nearly identical stories!
    His cool professor gave him an A+ for this report.
    Titanic:.... Cost - $29.99
    Clinton :..... Cost - $29.99
    Titanic:..... Over 3 hours to read
    Clinton :... Over 3 hours to read
    Titanic:..... The story of Jack and Rose, their forbidden love, and subsequent catastrophe.
    Clinton :... The story of Bill and Monica, their forbidden love, and subsequent catastrophe.
    Titanic:.... Jack is a starving artist.
    Clinton :....... Bill is a bullshit artist.
    Titanic:.... In one scene, Jack enjoys a good cigar.
    Clinton :.... Ditto for Bill.
    Titanic:..... During the ordeal, Rose's dress gets ruined.
    Clinton :..... Ditto for Monica.
    Titanic:..... Jack teaches Rose to spit.
    Clinton :.... Let's not go there.
    Titanic:..... Rose gets to keep her jewelry.
    Clinton :.... Monica' s forced to return her gifts.
    Titanic:..... Rose remembers Jack for the rest of her life.
    Clinton :...... Clinton doesn't remember Jack.
    Titanic:..... Rose goes down on a vessel full of seamen.
    Clinton :...... Monica... ooh, let's not go there, either.
    Titanic:..... Jack surrenders to an icy death.
    Clinton :...... Bill goes home to Hillary - basically the same thing
  16. Oct 6, 2011 at 8:23 PM
    #1656
    6L PSD
    6L PSD Well-Known Member
    North Pole, AK
    '11 4x4 DCSB OR TXP
    Fogs anytime, locker anytime, Moose lights (Lightforce), Randy Ellis Design light bar
    Dr. Watson arrives back at 221b Baker Street after a long day at surgery. He is surprised to walk in and find Sherlock Holmes smearing lemon curd across the bare buttocks of a young lad. "I say Holmes" gasped Dr. Watson, "what are you doing? What is that?" he demanded.
    Holmes replied "A lemon entry, my dear Watson!"
  17. Oct 8, 2011 at 3:13 PM
    #1657
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    How many engineers does it take to change a lightbulb? None, they just declare darkness as the new industry standard
  18. Oct 8, 2011 at 3:21 PM
    #1658
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Old but still funny. :D
  19. Oct 11, 2011 at 9:07 PM
    #1659
    T-Rex266
    Elon
    W.I.F.E.
    Wash
    Iron
    F...
    Etc
  20. Oct 12, 2011 at 5:54 AM
    #1660
    johneman
    Ken
    Warwick,Bucks PA
    I take it you aren't married!!!!:ballchain:
