Joying Head Unit - 2nd Gen/JBL - No Audio
Discussion in 'Audio & Video' started by twostring, Aug 29, 2021.
  1. Aug 29, 2021 at 11:58 AM
    twostring
    twostring [OP] Active Member
    I have tried every wiring combination possible on this unit. I've tried turning the amp setting on and off. All I get through the speakers are chirps when I select things on screen, but no audio from any source will play (radio, youtube, bluetooth...I can see the tracks playing). Does anyone have a solution for this? Their email support is useless.
    https://www.joyingauto.com/joying-9...or-toyota-tacoma-2005-2015-apple-carplay.html
  2. Aug 31, 2021 at 9:11 PM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    What year is your truck? Did you get the canbus harness?
  3. Sep 2, 2021 at 9:18 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Ok so your getting sound to the speakers based on the fact that you get the chirps from pushing buttons.
    There are a few things I can think of that may be causing a issue, while I dont know the menu that they are in, I know they are in there somewhere.
    There is a "sound normalization" setting, this adjusts volume of each input source. Check these to make sure they are not muted
    There is a "turn off sound while in reverse" setting, try turning this off. Your headunit may be thinking your in reverse all the time so it mutes the volume.
    There are also a few sound settings for adjusting volumes in there, but I dont remember the names.
    Basically there are like 5 things in the settings that can turn off sound. My best advice is to turn on FM radio, then go through every single setting in every single menu (there are 3 "settings" menus) and check each and every one of them.
    twostring[OP] likes this.
  4. Sep 2, 2021 at 9:26 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    the problem first and foremost is: "MADE IN CHINA".
  5. Sep 3, 2021 at 3:18 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Find me a radio not made in China lol
    Canadian5Lug and 5nahalf like this.
  6. Sep 9, 2021 at 4:53 PM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    Hey OP,
    Did you figure your issue out?? Curious because I'm looking at replacing my HD and this is one of my choices I've narrowed down to.
  7. Sep 18, 2021 at 10:27 AM
    twostring
    It looks like it's either the wiring harness or the connector on the back of the head unit. I happened to get some time to deconstruct my truck again and was holding the head unit this time, and the harness at the back of the unit was at the right angle to actually get sound out of the speakers, but it's for sure a loose connection or faulty connector. I'll go another round with their support to see if they'll replace any of it.
    Rascal737 likes this.
  8. Oct 5, 2021 at 5:23 PM
    Pjacoby253
    Pjacoby253 New Member
    Paul
    2010 Tacoma DCLB
    Lift tires
    Any update I’m currently having the same problem from what I can figure I need an additional wiring harness to keep my jbl amp I ordered the pac taco wiring harness from Amazon while I’m waiting to hear from joying
  9. Oct 5, 2021 at 5:40 PM
    apoteker
    you have the JBL in your 2010? i have narrowed my issue to something with the canbus adapter. I have a 2012 non-jbl that i converted to 2013 jbl stereo + 2009 jbl amp/sub back in 2014. When i installed this, i created a new harness that plugged into the oem wiring so i can easily try different combinations. As you can see, the factory connectors in the 1st picture connect to an adapter harness in the 2nd picture. This 24 pin connector is then connected to the joying harness as shown in the 3rd picture.
    In this wiring setup the original female speaker plugs are connected to the return from the 2009 year amplifier. AS mentioned in a previous email, this year amplifier does not have a separate tweeter output but has front R/L and rear R/L and sub output. I currently have the joying speaker out connected to the front speakers and the rear speakers connected to the amplifier output (setup 3 below). This allows for the subwoofer to work but I cannot accurately set the audio levels as when all speakers are connected to the amplifier. I think my phone audio issue could be solved by using a canbus adapter from an earlier vehicle (eg prado 2010) which would allow for the correct setup and not utilize the seperate tweeter output for phonecall audio.
    To summarize:
    Setup 1 (JBL): joying installed using canbus adapter (TY-SS-05) and setup to camry with amp; amp output connected to all speakers
    (a) audio levels work, subwoofer works, sound is good
    (b) phonecall audio output does not work
    Setup 2 (Non-JBL): joying installed using canbus adapter and setup to camry without amp; amp output disconnected; joying output connected to all speakers
    (a) audio levels (front/rear) adjustable, subwoofer does not work, sound is not as good as in setup (a)
    (b) phonecall audio output works
    Setup 3 (Hybrid): joying installed using canbus adapter and setup to camry without amp; amp output connected to rear speakers, joying output connected to front speakers
    (a) audio levels (front/rear) not ideal, subwoofer works, sound is not as good as in setup (a)
    I would like to try a different canbus adapter, i see TY-SS-01 listed in several similar setups... not sure if this is the correct part or if there is a different one
    [​IMG][​IMG][​IMG]
  10. Oct 5, 2021 at 5:48 PM
    Pjacoby253
    Paul
    2010 Tacoma DCLB
    Lift tires
    Thanks for the update I’m still waiting to hear what joying says and for he other adapter to arrive on Friday I’ll post my results here
  11. Oct 20, 2021 at 10:24 PM
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    I’m about to purchase but want to make sure I order correct harness. I have stock 2011 jbl unit. How do you reach them?
    is this issue only on the 9 inch?
  12. Oct 21, 2021 at 6:49 AM
    Pjacoby253
    Paul
    2010 Tacoma DCLB
    Lift tires
    I couldn't get mine to work with my JBL I ended up sending it back
  13. Oct 21, 2021 at 10:07 AM
    Tac11
    Luis
    :( That sucks. What you end up going with?
    Anyone had any luck doing it to their second gen w stock jbl?
  14. Oct 21, 2021 at 5:24 PM
    Pjacoby253
    Paul
    2010 Tacoma DCLB
    Lift tires
    I had a pioneer 6 inch screen before I just put that back in
    Tac11 likes this.
