JRZ Double Adjustable Prototype Lift & Info
Discussion in 'Suspension' started by cmr076, Jul 24, 2023.
  1. Jul 24, 2023 at 11:04 AM
    cmr076
    cmr076 [OP] Member
    David
    2019 Cement taco O/R DCSB 6mt
    I figured I would post this here as a lot of you guys seem to love the really Gucci, high end lift setups.
    My back story… I work in a management role for two firearms manufacturers… However, in a past life I worked for Porsche, from there I worked for myself managing a couple of clients massive collections (buying cars into, selling cars out of, etc), from there I owned a high end performance/dyno shop. At each stop along the way I made industry friends/contacts which lead to me getting some pretty cool products to test/evaluate. One of those companies is JRZ. If you’re familiar with their name you know they mainly do crazy high end/bespoke suspension setups for exotic and race cars; time attack cars come to mind, various formula cars, my person favorite, the gulf racing mclaren f1 gtr. They have been wanting to branch out and expand to other markets, they started that expansion supplying military trucks and armored cars with suspension, and recently have been getting into off road applications.
    I should have the kit for my truck in the next week or two, and will knock out the install as soon after that as I can. The highlights of the kit are:
    • bolt-on
    • Leveling and up to 2 inch lift
    • Improved handling on and off road
    • Better comfort level
    • Better stability of vehicle body
    • 14 clicks compression
    • 21 clicks rebound
    • Fine yet noticeable change per click
    • High volume canister
    • Adjustable gas pressure
    • Heavy Duty bearings
    • Fully rebuildable
    • Custom spring rates possible.
    I’ll keep this post updated with pictures and info, if there’s any specific questions about the kit, the company, whatever, post here and If I don’t know the answer, I’ll get an answer for you.
    :: disclaimer:: I don’t work for jrz, however I am friendly with them and have a long professional relationship with them. I’ll be honest about the install and driving impressions, and won’t sugar coat anything. If my past experience with their suspension components is any indication, these things will be amazing.
    Torspd, SUMOTNK, t0ba and 2 others like this.
  2. Aug 1, 2023 at 10:24 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Torspd and TnShooter like this.
  3. Aug 2, 2023 at 5:50 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Hmmm. My Tacoma has been identifying as a gt3 lately. I am interested.
  4. Aug 2, 2023 at 6:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Aug 2, 2023 at 7:13 AM
    eurowner
    eurowner Duke Sky
    Scoty
  6. Oct 24, 2023 at 8:55 AM
    SUMOTNK
    Eddie
    @cmr076 Did this kit ever get delivered and installed?
