Judge my New System
Discussion in 'Audio & Video' started by msc219, Sep 4, 2011.
  1. Sep 4, 2011 at 2:25 PM
    msc219
    msc219 [OP] Member
    Black 2010 Double Cab
    I decided to go with:
    The only reason I went with the Sony's in the rear is they were the best that Crutchfield had listed as "fitting" the rear doors. Hopefully that doesn't end up being a big deal...
    Anyway, I'm waiting for all this equipment to come in and will have it professionally installed. What do you guys think about the setup?
  2. Sep 7, 2011 at 3:23 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    What amp are you using for your subwoofer?
  3. Sep 7, 2011 at 3:32 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Looks good, and should sound nice
  4. Sep 7, 2011 at 4:25 AM
    meantaco
    meantaco Well-Known Member
    Andres
    2005 Prerunner. Gone,but not forgotten.
    Retrofit,bull bar,hellas and color matched grill.
    Im guessing he is going to use the pdx 5...
  5. Sep 7, 2011 at 3:46 PM
    msc219
    msc219 [OP] Member
    Yeah, I'm using the PDX-5 for the 300 watts to the JL sub
  6. Sep 7, 2011 at 7:34 PM
    brian
    Elizabeth City, NC
    Ah would have thought a 4 channel you'd use for doors.
  7. Sep 7, 2011 at 7:38 PM
    Slapps74
    Slapps74 Well-Known Member
    Thornton
    2014 FJC
    Bone stock for now!
    Should sound good. You will like that PDX amp. Sub could prob take more but nice set up
  8. Sep 7, 2011 at 7:43 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I think it is a solid system
  9. Sep 7, 2011 at 7:44 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    you will regret the sony xplod stuff, but other then that not to bad
  10. Sep 9, 2011 at 6:31 PM
    msc219
    msc219 [OP] Member
    They sound like crap? Anyone have a better suggestion for the rear door speakers? From what I've read, the mouting depth for them is fairly limited. I figure I can just fade to the front since the back's will just be for "filler" anyway.
  11. Sep 9, 2011 at 10:21 PM
    meantaco
    Andres
    go with the same mm series coaxials for the back.. when are you planning to buy everything?
  12. Sep 10, 2011 at 9:11 AM
    msc219
    msc219 [OP] Member
    I already bought everything. I've heard the mounting depth on the MM651 is an issue for the rear doors.
  13. Sep 10, 2011 at 9:42 AM
    msc219
    msc219 [OP] Member
    Do you think I'm better off bridging two channels to allow 150 X 2 to the front Polks and then running the rear speakers to the back Sony's? Or is powering all 4 speakers with the amp the best option? I just wasn't sure if overpowering the sony's (40 watts RMS) with the 75 RMS amp would be too much.
  14. Sep 10, 2011 at 9:45 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    I would bridge the channels and give everything to the front speakers. Run the rears off the headunit. You will get better sound because the gain on the amp will not be turned up as high.
  15. Sep 10, 2011 at 11:50 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    ^^this guy has no idea what he is talking about, wow....
  16. Sep 10, 2011 at 1:29 PM
    brian
    Elizabeth City, NC
    You might as well not even have the rear speakers if you do that bud. Better sound because the gain will not be as high? As high as what? Its an alpine buddy, not your little pentagon shaped sony amp you bought at wally world. :)
    So anyways, I'm confused here, originally we were talking the amp for the sub.... now were talking the amp for the coaxials.... which will it be?
    If you ask me Id have two amps :)
  17. Sep 10, 2011 at 1:38 PM
    fishntaco
    Josh
    Mobile Al
    Yeah I just read what i wrote and that did not make a shit lick of sense. But why not bridge the four channels to two? The front speakers are doing most of the work anyway. Plus better imaging unless you like surround sound. The headunit should be plenty capable of running the rears for when passengers are riding.
  18. Sep 10, 2011 at 1:42 PM
    brian
    Elizabeth City, NC
    You seriously won't even hear them if they run off of deck power, and will probably distort if you attempt to "match them up" volumewise.
    Run the sonys till they live up to their name, or get some new speakers. I'm suggesting the latter. If you want cheap components, the absolute cheapest I could suggest would be wally world Pioneers, they get the job done.
  19. Sep 10, 2011 at 5:07 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    why bother buying a 4 channel amp and bridging it to 2 channels? generally 4 channels are alot bigger than 2 channels, so just buy a higher power 2 channel and be done with it.
  20. Sep 10, 2011 at 7:18 PM
    Slapps74
    Thornton
    2014 FJC
    Bone stock for now!
    I have Focal 6.5 components in the front and Focal 6.5 2 ways in the rear doors with the taco tunes adaptor kits. I run a JL XD400/4 on the doors and a JL XD600/1 on a JL stealth box with 2 10's and it sound wicked!
